Front Forks
Old Mar 13, 2009 | 09:10 PM
wolfydude's Avatar
wolfydude
Default Front Forks
Hi
Just wondering if anyone can help with this.
I own a 2007 FXDC,i have replaced the factory rear shocks 12.5" for 11.5",i was wondering if is ok to lower the front end say an 1" by just pushing the front forks higher through the trees (Yokes).
Wolfy
Old Mar 13, 2009 | 09:21 PM
jordanball33's Avatar
jordanball33
i think long as you keep them the same on both sides an inch should be good. im gonna do the same myself, and have seen some done like this before. so unless i hear other wise im going for it too
Old Mar 13, 2009 | 09:36 PM
wolfydude's Avatar
wolfydude
Cheers Jordan
Thanks for the help.
I know a lot lower the forks this way on their sports bikes to get more weight on the front end for better handling.
But wasnt sure if this was fine with the big cruisers.
Thanks Again
Wolfy
Old Mar 14, 2009 | 04:40 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Default Fork tube raise
Just did it a few days ago as a way of seeing if it would help buffeting by clamping the QD above the top tree. Notice NO handling differences so far; jury still out on buffeting, though it DOES open up a big-a$$ hole for air to get in above the headlight. If you try it and before shearing off any T-45 tools in the clamp bolts, take Joe's advice and give each bolt a good shot with a hammer and punch. I used a punch that just fit inside the splines, and a 3/4 serious blast from a 32-oz ballpein...could'a removed 'em one-handed with a 1/4" drive Taiwanese Torx after that (thanks Joe!!)
Attached Thumbnails Front Forks-keyboard-019.jpg   Front Forks-keyboard-020.jpg   Front Forks-keyboard-021.jpg
SlimsSG
May 5, 2013 05:45 PM
tincup64
Mar 11, 2012 12:20 PM
jcmusic
Jul 30, 2009 10:30 AM
firefly55
May 3, 2008 09:46 PM
captain m
Jan 1, 2008 09:47 AM
