oil temp gauge
Old Mar 16, 2009 | 02:07 PM
mud's Avatar
mud
Originally Posted by sickwithit
Mud,
So the only way to add a oil temp gauge it to add a oil cooler.
Or is their another spot you can tap the line?
I'm sure you could jig up something off the port where your
stock Oil Pressure Sender is located.
mud
Old Mar 16, 2009 | 03:20 PM
dlstanf2's Avatar
dlstanf2
Here is what an Oil Temp Sensor looks like. Basically, it is a thermocouple that sits in your oil stream. The output of the thermocouple is in millivolts and this is read by your Oil Temp Gage. You can use a T-Fitting just below your Oil Pressure Gage and install the Oil Temp Sensor. Then connect the wires, Bat., Gnd., Signal. Sometimes it is a two wire sensor, Bat. & Sensor. Ground is the temp sensor body which connected to the motor and then by a ground to the frame and eventually back to the battery. (All the same, just has to be a good contact)
Attachment 33702
Here's a link to a good read on how a temp sensor is set up for a touring model, the HD MoCo instructions.
http://hawgzone.com/uploads/forums/o...uge_adapt..pdf
Old Mar 16, 2009 | 07:30 PM
roadhouse's Avatar
roadhouse
if hooked to an oil cooler line, should it be before or after the cooler, im sure there are a few different opinions, just want to see a couple different, id assume pre cooler,because thats what your engine would be runnig at.
Old Mar 16, 2009 | 07:37 PM
Dawg Rider's Avatar
Dawg Rider
Anybody tried one of those dipsticks with the digital temp gauge on top? Not exactly easy to see while underway, but cheap and easy.
Old Mar 16, 2009 | 07:39 PM
roadhouse's Avatar
roadhouse
thats what i had in mind at first but they dont make them for my bike, 07 fxdb
Old Mar 16, 2009 | 09:04 PM
ronny c.'s Avatar
ronny c.
why dont they make an oil temp. dipstick for the newer bikes like they did for all the other bikes?
Old Mar 16, 2009 | 09:18 PM
mud's Avatar
mud
ronny, all the other bikes................ pre 006
006 and up has a swingin dipper,
maybe someone will make one available soon,
and make a killing........
Old Mar 16, 2009 | 09:54 PM
dlstanf2's Avatar
dlstanf2
RoadHouse, I thought about this on the way home today; you need to be as close as possible to the hottest path for your sending unit. i.e., right around the oil filter adapter.
Mud is just to cool with his ideas. Love the finger.
I have seen a digital Oil Temp sensor for the Oil Fill. But, it was battery operated, (coin cell), and you had to push a button for the read out. Definitely not readable while riding.
Old Mar 16, 2009 | 10:17 PM
ronny c.'s Avatar
ronny c.
common since, i gotta try that sometime.
Old Mar 17, 2009 | 12:12 AM
r00k's Avatar
r00k
Mud, it has to be convenient to have what is basically a knife threaded in your bike.
