Ridin' Hard
Old Mar 16, 2009 | 12:58 AM
LilBudyWizer's Avatar
LilBudyWizer
Just a suggestion, but lean you, not the bike. If the goal is to drag then fine, but if the goal is to open it up and enjoy a twistie then you need to use your weight to your advantage.
Old Mar 16, 2009 | 01:09 AM
jake.h's Avatar
jake.h
Damn, does everyone wear sneakers when they ride? LOL. I prefer me a good pair of boots!
Old Mar 16, 2009 | 01:26 AM
jake.h's Avatar
jake.h
BTW, here is a tid-bit of info I found on the web about rider leaning/ground clearance:
Why do Road Racers Stick Out Their Inside Knee?
It lets the bike lean less for a given speed. By sliding off the inside of the seat, the rider's body weight is moved towards the inside of the corner. This means the bike needs less lean for a given speed and turn radius. As ground clearance is often the limiting factor in cornering (particularly at higher speed) this allows the rider to corner at higher speeds.
Here's some nerd info that describes turning geometry:
T = arctan [V^2/(G*R) ]
V is your velocity, R is the radius of your turn, G is the gravitational constant. T is the "lean angle." It's the angle between (1) the horizontal, and (2) a line from the contact patch of your tires through the center of gravity of the bike-rider system.
Hanging off and sticking out your knee moves the center of gravity of the system to the inside, while leaving the bike more upright, so you don't run out of ground clearance.
Old Mar 16, 2009 | 03:00 AM
kromer4life's Avatar
kromer4life
Yep cuz its the G thang to do
Old Mar 16, 2009 | 03:49 AM
devils haircut's Avatar
devils haircut
That was point. I'm just too damned un-edumacated to know all the math behind it.
Originally Posted by SuperG
Ackman, that smoke not actually from my shoe it was from
my primary, grinded a decent chunk
Greenyetti, im running drag bars.
As far as countersteering goes a harley can only really go so much
and i think i ride my bike to its limit and a bit more.
Are you gonna replace that primary cover? I wouldn't, I'd keep it as a badge of honor...kind of a "chicks dig scars" thing! BTW, nice kicks.
Old Mar 16, 2009 | 05:11 PM
chad peterson's Avatar
chad peterson
I see your point devil & you're right, that would be the mathematical way of cornering as far as geometry goes. I've got old habbits, been ridin dirt bikes since I was 6 & in no way am I willing to change (that would completely fu**me up)! Throw my leg on the dirt bike & swing my knee on my dyna, been doin it for years & never had a problem cornering. Sh** dude I'm so used to it, I bet if I tried your way & hung off the side of my seat to corner I'd probably crash! Lol
Old Mar 16, 2009 | 06:47 PM
jwlehman's Avatar
jwlehman
It looks cool, but I paid too much for my bike to scrape it up on turns. If I wanted to ride like that, woulda got a trail bike. Guess I'm a sissy
Old Mar 16, 2009 | 06:53 PM
MZBuckeye's Avatar
MZBuckeye
Nice pic, that's what I'm talkin' about! Do you have a True Track on that bike?
Old Mar 16, 2009 | 07:04 PM
sata6's Avatar
sata6
shiit that's nothin i used to race sport bikes try scraping your elbow.
Old Mar 16, 2009 | 07:09 PM
SuperG's Avatar
SuperG
No true track on my bike.
