shifter help needed
Old Mar 18, 2009 | 09:53 PM
RandyS's Avatar
RandyS
Default shifter help needed
Please read my post...thanks:
https://www.hdforums.com/forum/gener...oorboards.html
Old Mar 20, 2009 | 09:40 PM
RandyS's Avatar
RandyS
Someone must have some ideas for me......I really need your thoughts and advice..thanks guys!
Old Mar 20, 2009 | 09:45 PM
ackman1968's Avatar
ackman1968
Did you do a search? There was a thread on here addressing what you are up against. I know one guy built a bracket to go from the shifter mount to one of the mounting brackets. Another guy used a kit for a bagger that put a heel/toe shifter on it.
Here's the link... https://www.hdforums.com/forum/dyna-...ater-dyna.html
Old Mar 20, 2009 | 10:20 PM
donr101395's Avatar
donr101395
Like you mentioned in your original post, I'd cut, weld and refinish first if it were me.
But then again I have a welder, love spray paint and like to tinker.
Old Mar 21, 2009 | 09:27 AM
RandyS's Avatar
RandyS
Ackman...I did follow that thread closely...a bracket is an option, just not sure of it with vibration, etc and lining it up just perfectly - may be more work than riding...thought the shifter extension may be the way to go...
Donr - I have a welder too....what type of medal do you think that is, as mine is a stick welder - do you think that I would have any troubles with going too long that it would not be a nice shift...too high or too low down due to the extension?
Old Mar 21, 2009 | 09:34 AM
donr101395's Avatar
donr101395
The only way to know is to strip it to see, hopefully it's not cast. If it is weldable you may have to sleeve it because it's so thin. I'd be willing to mess with it though for two reasons 1. it's not very usable the way it is 2. worst case scenario I have to buy a lengthened shifter which is what I would have to do even if I didn't mess with it.
Old Mar 21, 2009 | 09:59 AM
RandyS's Avatar
RandyS
Lol....exactly...need a new one anyhow! That is what I am afraid of though that it is cast....guess I will find out! Thanks.
VirtualNorm
Jun 29, 2015 05:49 PM
roadglidedude
May 31, 2011 08:28 AM
Evo94
Jan 3, 2009 03:42 AM
kelly hooper
Apr 9, 2008 08:46 PM
MoesSS
Feb 10, 2006 08:07 AM
