Need "Long" stems for my mirrors..advice?
Old Mar 29, 2009 | 02:38 AM
118811fh's Avatar
118811fh
Default Need "Long" stems for my mirrors..advice?
HI all,
Tired of looking at my shoulders!!! I need some long mirror stems
Would like to keep the factory mirrors
Anyone know where I can get some on the net?
Thanks for the advice
Aloha,
Frederick
Old Mar 29, 2009 | 07:46 AM
08fxdf43202's Avatar
08fxdf43202
I'm not sure what you're riding... but some of it has to do with where the bars position your hands.
I've got an 08 FXDF with Fat Boy bars & risers... these are the mirrors I'm using (the 3" ones):
http://www.jpcycles.com/Search/Produ...ort&results=10
There are optional long stems available (the mirror & stem are two seperate pieces):
Old Mar 29, 2009 | 07:54 AM
bberck's Avatar
bberck
I had the same issue when I switched to drag bars.
I know you said you wanted to keep the stock mirrors but incase that isnt a option here is what I bought.
Kury Magnum Plus - they have 2inch longer stems and I can see again
Old Mar 29, 2009 | 08:04 AM
ELECTRICMONKEY's Avatar
ELECTRICMONKEY
I have the same problem I put on narrower zbars and now i cant see. I'm thinking of putting on bar end mirrors from joker machine but they are very pricey. I'd really like to see if you find a solution and let us know.
Old Mar 29, 2009 | 09:12 AM
kmealp's Avatar
kmealp
When I went to drag bars I had the same thing. Bought a set of after market mirrors but they vibrated to much. went with paul yaffe grips and grip end mirror. They cost but I got lucky and got the mirror and stem on ebay. I like the look and works great.
Attached Thumbnails Need "Long" stems for my mirrors..advice?-rec.randoms-415438132.jpg
Old Mar 29, 2009 | 09:17 AM
ELECTRICMONKEY
Do you have to move your hand position to see in the mirrors?
Old Mar 29, 2009 | 10:29 AM
07fxdwg's Avatar
07fxdwg
I got the Harley long stem stock mirrors for my Street Slammers. Had same problem and longer stem took care of it. pn 91846-03A and 91848-03A. Page 591 in 2009 HD catalog.
Old Mar 29, 2009 | 10:53 AM
Grind's Avatar
Grind
I did the same, but only on the left, so far. They're not much longer, but they make world of difference. You can also get mirror extensions. PN 91907-87
Old Mar 29, 2009 | 11:01 AM
OhioSkully's Avatar
OhioSkully
The mirror extensions work and are the quick and easy cheap way to keep your stocker mirrors. Dad put them on his ultra and they made a world of difference in seeing around the tour pack.
Old Mar 29, 2009 | 03:21 PM
118811fh's Avatar
118811fh
Do theses extensions attach to the bars..then you attach the original mirror & stem to the extension?
Thanks
