07 FXD torque sequence for primary cover
Old Mar 30, 2009 | 03:15 PM
treynolds155's Avatar
treynolds155
Default 07 FXD torque sequence for primary cover
Searched posts but the links were screwed up. Picked up a chrome cover over the weekend and it didn't have any instructions, dealer said to just go around in a circle. That didn't pass the stink test.
I know to go ~110 in/lbs and start in the middle and go outwards switching from top to bottom while alternating left to right but I would prefer the exact specs.
Thanks
Tim
Old Mar 30, 2009 | 03:56 PM
blackmopar's Avatar
blackmopar
dont have the book on me, but if memory serves, its middle bottom, then alternate up down as you go out - ill check back on thread if i can tonight and if no one repsponded ill post the diagram
Old Mar 30, 2009 | 04:52 PM
dyna rider's Avatar
dyna rider
Default Derby Cover
84-108 in lbs Sequence is like a clock dial 12-8-2-10-4 This is from the service manual.
Old Mar 30, 2009 | 05:22 PM
treynolds155
Thanks guys, a lot of conflicting info out there on such a simple thing.
Old Mar 30, 2009 | 05:44 PM
Splatter's Avatar
Splatter
treynolds155 -- That's the sequence for a derby cover -- is that what you meant? Or did you mean the cover that's covering the whole primary drive?
Old Mar 30, 2009 | 06:01 PM
dyna rider's Avatar
dyna rider
Default Primary Cover
That sequence is for the derby cover. If your doing the primary, PM me and I will send you the info for that.
Old Mar 30, 2009 | 06:07 PM
Naz_Man's Avatar
Naz_Man
Thanks
Tim
Naz
Old Mar 31, 2009 | 06:13 AM
treynolds155
Thank Naz, my primary cover has 13 holes but this will do the trick nicely and confirms I was wrong....alternate top and bottom working to the front, then work your way back.
Appreciate the post
Tim
californiafatbob2013
Oct 21, 2013 09:37 AM
capo58
May 8, 2013 05:38 PM
02LowRiderFla
Jun 8, 2012 02:04 PM
gconklin
15
Jul 2, 2010 07:34 PM
jmpancoast
Mar 2, 2007 08:19 PM
