Headlight
Old Apr 1, 2009 | 10:57 AM
jcmusic's Avatar
jcmusic
Default Headlight
I have an 04 Low Rider and want to install a Billet style headlight, problem is the mounting. Can anyone help me with the mounting? My stock headlight mounts from the top and there is no place to mount the Billet style light on the lower triple tree.
Jay
Old Apr 1, 2009 | 11:05 AM
thedonthere's Avatar
thedonthere
I would drill a hole in the lower tree if it was me.
Old Apr 1, 2009 | 11:25 AM
shimmon's Avatar
shimmon
Originally Posted by thedonthere
i would drill a hole in the lower tree if it was me.
i think that is the correct action to take... Or have a mounting tab welded on (but this may require removal of lower triple tree)
Old Apr 1, 2009 | 11:26 AM
Streets of Fire's Avatar
Streets of Fire
I drilled and tapped the hole in the lower tree on mine. I can take pics tonight. Here are the few I have.. PM me with any questions.
dummy light mount / tripple tree cover
http://www.headwinds.com/mm5/merchan...ry_Code=010502
Old Apr 1, 2009 | 11:30 AM
JRK5892's Avatar
JRK5892
that looks great!
Old Apr 1, 2009 | 11:32 AM
rounder's Avatar
rounder
just drill a hole. No need to tap it as the lower trees are not threaded. Also you can purchase a chrome trim plate that bolts right where the current brow is located. The trim plate is stock on the sportster custom model so you can get the part # from that.
Old Apr 1, 2009 | 12:11 PM
fixxr's Avatar
fixxr
If you want to spend the money you can buy a lower tree from a 1200 C it will bolt right on.I would just drill it.
Old Apr 1, 2009 | 02:01 PM
jcmusic's Avatar
jcmusic
I seen some top mounting lights on the Headwinds website, does anyone know anything about them?
Jay
Old Apr 1, 2009 | 02:14 PM
coppertop666's Avatar
coppertop666
i've seen them before and didn't really care for the look with the eyebrow. I think your best bet is to drill the bottom tree or get a new set of tree's like I did - used to be vulcanworks.com but now exclusively on ebay http://stores.shop.ebay.com/Vulcanwo...34Q2ec0Q2em322
Old Apr 1, 2009 | 04:11 PM
jcmusic's Avatar
jcmusic
What do you mean with the eyebrow?
Jay
