powder coating question
Old Apr 2, 2009 | 08:30 AM
ratt196635's Avatar
ratt196635
Default powder coating question
I am going to have some cast wheels coated soon. What is the best way to have them coated. Coat inside of the rim where the tire mounts or not coat where the wheel mounts?
Old Apr 2, 2009 | 09:58 AM
powdercoater's Avatar
powdercoater
That sounds like a question YOU have to answer... unless it's not your bike. I'd suggest hitting up the guys on here that do PhotoShop to give you a rendering both ways. Once you see it you'll know right away which way looks best for you.
Old Apr 2, 2009 | 10:19 AM
ratt196635's Avatar
ratt196635
I am getting the outside coated I am talking about the part you dont see when the tire is mounted.
Old Apr 2, 2009 | 11:14 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Doesn't need to be coated, a little over spray won't hurt any.
Old Apr 2, 2009 | 11:17 AM
powdercoater
Aaaaaaah! I misunderstood, sorry. In that case it really doesn't matter so long as the beaded edge is done so when the tire is installed everything you see is powder coated. The exception to that would be if the rims are steel, and I know yours aren't.
However, it's my opinion that a good powder coat shop that is focused on quality will coat the inside (tire area) as well so all the metal is coated and protected from corrosion.
Old Apr 2, 2009 | 11:18 AM
JRK5892's Avatar
JRK5892
Old Apr 2, 2009 | 12:02 PM
ratt196635's Avatar
ratt196635
Thats what i wanted to know. I wanted it all coated so I will have them coat it all. except where the rotors bolt on and pully and rotor on the rear one.
Thanks guys!!!!!!!!!!!
Poisond 08 Fatbob
Powdercoat & Paint
Dec 6, 2013 02:28 PM
philc814
Dec 10, 2012 05:21 AM
Augustus
Aug 29, 2011 06:17 PM
ltcurt33
Powdercoat & Paint
Jun 21, 2011 04:40 PM
bucket13
Feb 11, 2011 08:46 AM
