Wide Tire and Rims
Old Apr 2, 2009 | 08:34 AM
jcmusic's Avatar
jcmusic
Default Wide Tire and Rims
I have an 04 Low Rider and want to install the widest rear tire that I can without modifiying the swingarm. I also want new chrome rims and want to do both at the same time. What size rims for what size tires do I need to look at?
Jay
Old Apr 2, 2009 | 08:39 AM
formike56's Avatar
formike56
Jay
There are a couple of company's that will chrome your stock rims. Or swap them out. You can put a SE180 on the rear with out any modifications.
Old Apr 2, 2009 | 08:42 AM
jcmusic's Avatar
jcmusic
Remember I have an 04, are you sure that a 180 tire will fit my stock rim?
Jay
Old Apr 2, 2009 | 09:46 AM
red devil's Avatar
red devil
Usually you can go up 1 size and not have a problem. Is your stock tire size 150mm? How about rim size, 3.5"? The SE 180mm won't fit.
Old Apr 2, 2009 | 10:20 AM
jcmusic's Avatar
jcmusic
So are you saying that a 160 is as big as I can put on my stock rim if it is a 3.5?
Jay
Old Apr 2, 2009 | 05:14 PM
jcmusic's Avatar
jcmusic
Yes my tire is 150mm I am not sure about the rim size.
Jay
Old Apr 2, 2009 | 08:32 PM
bigVtwin88's Avatar
bigVtwin88
I have an 05 and I'm cursed with the same problem. A 160 may fit, I've heard opinions both ways, but anything beyond that is a no go. If I go bigger, it's gonna be with a kit to run a 240. $$$$$$$$$
Old Apr 2, 2009 | 09:06 PM
last saint's Avatar
last saint
You CANNOT run a 180mm on your 04 without some extensive mods. It can be done, but it takes a lot of work and money. You have to decide if a 20mm difference is worth the cost. I ran a 160mm Metzeler on my 04 FXDL with a 18x4.25 rim without any mods whatsoever. Something to keep in mind, not all 160's are the same width...they vary slightly from brand to brand. Here's a pic of my 04 with the 18" 160.
Good luck!
D
Old Apr 2, 2009 | 09:45 PM
greenyetti's Avatar
greenyetti
JC I feel your pain bro. I have the same situation with my '03, have found that the 160 is my max without MAJOR $$$$ It will be cheaper for me to just trade up in a year or two. Let me know if you get a 160 on, brand etc. Good luck
Old Apr 3, 2009 | 05:35 AM
jcmusic's Avatar
jcmusic
Good luck!
D
That's good info thanks alot, I may try the 160. I don't know about the 18in rim, would like to stay with the 16in.
Jay
