Notching a Rigid Solo Rack
Old Feb 6, 2010 | 11:26 PM
  #31
Jutdees's Avatar
Jutdees
this is the way I went. I notched it but never take it off. I like the tall chopper look. I just put a rack on instead of the seat and strap my bag on.
Old Feb 7, 2010 | 07:14 PM
  #32
JimmieJack's Avatar
JimmieJack
I have thought about notching my solo rack. After reading this thread I decided to just notch the back side of the rack. By notching the back only I still had the security of having the front bolts run all the way through but in the back I would normally have to jack up the bike etc ... to get the rear bolts out. Now even though it is not a quick disconnect - now I can take the rack off fairly easy (if I need to). I also used some spray adhesive and put some felt on the inside of the rack bracket to help prevent scratching the fender when removing or reinstalling the rack.
Attached Thumbnails Notching a Rigid Solo Rack-motorcycle-007.jpg   Notching a Rigid Solo Rack-motorcycle-008.jpg
Old Feb 7, 2010 | 09:24 PM
  #33
Hooker 6's Avatar
Hooker 6
I have a Motherwell on my Lowrider and I can put a large T-Bay, or the roll, which is what I use most of the time, and the Motherwell looks so much nicer. IMHO.
Old Feb 8, 2010 | 07:25 PM
  #34
DMV11982's Avatar
DMV11982
Jimmie Jack, is it pretty secure?
Old Feb 8, 2010 | 10:18 PM
  #35
JimmieJack's Avatar
JimmieJack
yea, even with the notch its still on there solid. Like I was saying - I only notched the back so the front can't come of the bike unless you take the bolts out. I also included a couple of pics. - Before the saddle bags I had a detachable rack on my sporty - I attached a "tank bag" to the rack. I could store stuff like glasses, gloves, chaps, etc .... you can actually put quite a bit of stuff in there when you expand the bag. I know you can fit a couple of orders of chinese take-out too.
Attached Thumbnails Notching a Rigid Solo Rack-motorcycle-001.jpg   Notching a Rigid Solo Rack-motorcycle-002.jpg   Notching a Rigid Solo Rack-motorcycle-003.jpg
Old Feb 8, 2010 | 10:37 PM
  #36
DMV11982's Avatar
DMV11982
JimmieJack, can you give me the specs of how u cut ur solo rack? I just bought one today and I would like to do it just like you did...great idea!
Old Feb 8, 2010 | 11:13 PM
  #37
JimmieJack's Avatar
JimmieJack
DMV, I can't really say there is any "Spec." to how I did the cut. I simply took a jig-saw and cut down and across. I attached a little photo shop pic. - the blue circle is where the original hole was and the red lines are where I cut it.
I'll tell you this - becareful putting the rack on. It fits tight and when I first put it on I was careful but then I was messing around with the saddlebags and had to move the rack up and down a little and I stratched up the fender on the other side. Since then I got some spray adhesive and some black felt from a craft store I sprayed the adhesive and attached the felt to the inside rail of the rack then cut off the excess. You can see a little of the felt in the picture.
Good Luck -
Had to resize the picture - hope it turns out.
Old Feb 13, 2010 | 09:55 PM
  #38
DMV11982's Avatar
DMV11982
Cool thanks!! Going to do this on Monday!! Hope my dremel will work!
Old Jul 10, 2010 | 04:27 PM
  #39
DutchBob's Avatar
DutchBob
I've notched my rack too, but a bit different so I still have some upward strength, though I think the way mentioned before is also strong enough. This just gave me a bit more confidence.
I also sprayglued some felt on the inside and it slided on real easy. I can take it off/put it on in less than 5 min. now.
Attached Thumbnails Notching a Rigid Solo Rack-img_0036.jpg   Notching a Rigid Solo Rack-img_0035.jpg
Old Jul 10, 2010 | 04:29 PM
  #40
DutchBob's Avatar
DutchBob
My dremel worked. Perfect for the job!
Jersey Drew
Sep 26, 2014 07:55 PM
Teufelhund
May 17, 2011 11:42 PM
mrt1
May 15, 2011 08:11 PM
Schaub85
May 5, 2010 12:41 PM
gdtrfb_ams
Aug 11, 2009 04:35 PM
