Just bought some chrome sliders for my 06 super glide and Im going to switch them out my self.Any advise ,do and donts recomended tools etc. .Any help Id sure appreciate
I just took mine apart to have them powder coated, and when the manual told me to place the forks in the special tool that mounts in a bench vise I just put them back in the triple tree's to hold them. other than that it's pretty straight forward.
Mine are the 49mm tubes. In the pix you'll see how I stabilized the stock lowers while I broke loose the 12mm socket-head damper bolt. Another member told me about getting the L-wrench at Sears ($7.99?). You can use the short end of the L-wrench on the right side bolt, but it's not long enough to reach up to the left side. I used a large combination wrench as a cheater. I'd say a M/C jack is a near-necessity, though with some big wood blocks and a bottle jack, you might be able to make-do as long as you have someone to help stabilize things while you try to break loose those 12mm bolts. I drained my forks thru those damper bolt holes atop the axle; yours won't take the same amount to refill as mine. With those bolts removed, you just use the lower like a slide-hammer to remove it from the tube AFTER removing the dust cap, dust seal, and oil seal retainer clip! PM me if you need any clarifications or add'l info.
Reason: Added one more link
Mud did a nice write up also. Dammit I cant think of the name of the pieces Mud bought to put in the bottom of the forks... I-something or other...may want to do that while you have it apart.
