putting 2 exhaust gaskets on each pipe
Old Apr 11, 2009 | 10:47 PM
snooper0069's Avatar
snooper0069
Default putting 2 exhaust gaskets on each pipe
I took off my pipes ( stock ) to do some work and put the same exhaust gaskets back in. They werent crushed or frayed and now im getting popping when I let off the throttle.Im guessing the gaskets or either worn or not seating. When I put the old gasket back in I did notice there is plenty of room for another gasket to go on top of the one already there. Im wondering if I put 2 on each exhaust if it would seal any better.
Old Apr 11, 2009 | 10:53 PM
Geezer2's Avatar
Geezer2
New gaskets and torque to specs. I would'nt put two in. jmho
Old Apr 12, 2009 | 08:47 AM
8541hog's Avatar
8541hog
+1
out with the old, in with the new. 2 gaskets does not make it double good, it doubles the chance for a leak.
Old Apr 12, 2009 | 08:59 AM
maddghost's Avatar
maddghost
2 gaskets you haave about 1 chance in a million tonot have problems! I'm with those guys just replace them with new-you should never re-use exhaust gaskets as they are crushed into form during initial install.that's why they didn't work for ya.
Old Apr 12, 2009 | 09:00 AM
kmealp's Avatar
kmealp
When I did mine they had two styles of gasket, a thin one and a thick one. Check and see if anyone has a different one from the one you have.
Old Apr 12, 2009 | 09:08 AM
Lennyone's Avatar
Lennyone
I can not see how two gasket would fix without leaking. One gasket install correctly will not leak unless there is a bad vibration problem with the exhaust header. There mitt be a crack in the end of the header by the exhaust.
Old Apr 12, 2009 | 01:00 PM
Mascman's Avatar
Mascman
I've had my pipes on and off so many times that I can't count. I've had stock, Short shots and Pythons.
Never changed the gaskets and don't have a problem.
I realize they are crush gaskets, but as long as they are not torn or pieces missing, they should seal.
My guess is that the seal is not seated correctly or the possibly at the flange.
trnewman
May 12, 2013 09:18 PM
hfp3030
May 1, 2012 09:43 AM
JakesDad1
Mar 25, 2011 09:55 AM
kawsakimx6
Feb 9, 2008 03:50 PM
dynarider
Exhaust System Topics
Jun 28, 2007 04:37 PM
