Exhaust Gasket - No Brainer... Right?
Old Mar 24, 2011 | 03:52 PM
JakesDad1's Avatar
JakesDad1
Angry Exhaust Gasket - No Brainer... Right?
Help....... I've picked out the old gasket, but the new one only goes in about half way. Am I doing something wrong????
Old Mar 24, 2011 | 06:16 PM
wiseguy2day's Avatar
wiseguy2day
It's a squish gasket. Put it in as far as you can, evenly all around, and put the exhaust in. Tighten up evenly and should be good to go.
Old Mar 24, 2011 | 06:26 PM
Uncle Larry's Avatar
Uncle Larry
+1 to what Wiseguy2day said ... take your time and tighten it up evenly. It will seal fine.
rockchalk08's Avatar
rockchalk08
I was able to get mine to go in so it was flush with the outside edge of the exhaust port. I guess gaskets could be different widths?
Old Mar 24, 2011 | 06:42 PM
brettnbama's Avatar
brettnbama
Rub some dawn around the outside of it, make sure the tapered side is toward the motor, and make sure you are putting it in square...
Old Mar 24, 2011 | 07:18 PM
TheTroupe's Avatar
TheTroupe
Jims Exhaust Gasket Tool...
Yeah it's $40.00 but it saves your thumbs and when your buddy changes his exhaust you'll be an F'n hero.
The gasket flat side is towards the engine the tapered side accepts the header. But I could be wrong.
http://www.google.com/#q=jims+exhaus...cf2c2a5706f548
shooker's Avatar
shooker
Yeah they might seem a little big try pushing them in gently and evenly with something blunt, I usually use a 1/4" nut driver.
Old Mar 24, 2011 | 08:36 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
that's how i've installed mine....take your time, no need for specialty tools...also agree with shooker, just be carefull not to warp it too much
Old Mar 24, 2011 | 08:46 PM
SpicOfTheDevil
got any recent pics?...was following your build thread but too much work kept me away from the net
Old Mar 24, 2011 | 09:01 PM
brettnbama's Avatar
brettnbama
You're right, brain fart....
