Reflector Removal
Old Apr 14, 2009 | 07:36 AM
Goddahavit's Avatar
Goddahavit
Seriously, if you need any help, send me a PM, apparently its BAD to ask questions in a forum
I'll help in any way I can.
Eric
Old Apr 14, 2009 | 07:51 AM
SC-Longhair's Avatar
SC-Longhair
No, not bad but there are many threads on that same topic. Why do we need another one? Isn't that what the search function is for?
Old Apr 14, 2009 | 08:47 AM
08FXDC's Avatar
08FXDC
Anyone worried about putting too much heat on the rear ones with the paint and all?
Old Apr 14, 2009 | 08:53 AM
SC-Longhair
I did not use any heat on any of them. I slowly and carefully pryed them up with a flathead screwdriver then when I could, grabbed them with my fingers and finished the job. Using a towel or thin piece of cardboard behind the screwdriver would be smart, so as to not scratch or mar the surface you're working with.
Old Apr 15, 2009 | 08:58 AM
von Wolffe's Avatar
von Wolffe
I used an all plastic pry bar to pop those suckers off then used WD-40 and a shop rag to remove the glue, oh and a lot of elbow grease. Clean up w/ some Windex and you're done.
Old Apr 15, 2009 | 09:59 AM
r00k's Avatar
r00k
Did the same thing as everyone else for the front and rear, I need to update my sig pic.
I've heard that using Goof Off will ruin your clear coat, so don't use that.
Goo Gone good, Goof Off bad.
Old Apr 15, 2009 | 10:32 AM
red devil's Avatar
red devil
Easy job! Don't forget the rear ones. I finally did the rear reflectors this winter and it really cleans up the fender!
Old Apr 15, 2009 | 10:49 AM
SURFOR Chop's Avatar
SURFOR Chop
Originally Posted by nfccrwr
Has anyone pulled off their amber reflectors from their front forks? They look like they are just stuck on with trim adhesive I would pull on it but with my luck it would snap and be a $35 replacement part.
So who do you call? HD Busters!!!! Thanks guys.
I would get rid of the rear fender reflectors too if they come off the same!
I snapped one of my reflectors in half when removing it ... I'll let you know how much replacements cost if, as, and when I buy one ...
I got impatient for it to heat up adequately and pried too hard ...
I have reviewed the Washington state laws on minimum operating equipment, but I don't remember what the requirement for reflectors was ... until I get cited for it, I don't plan on replacing them ...
R/
Priest
Old Apr 19, 2009 | 10:55 PM
LV_EOD's Avatar
LV_EOD
I did my fronts today. I set a hair dryer on a milk crate, aimed strategically, and let it heat up for a few minutes. Little bit of a start with a plastic knife and they both popped right off. The adhesive was more like a flat rubber seal than anything else, it rubbed right off with my bare finger into nice little booger *****. No muss, no fuss.
Old Apr 19, 2009 | 10:59 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
Dental Floss...I take all the badges off all my cars with it...just like butter
