I was shining her up today getting ready for summer when i got to the rear wheel disc brake side there is all this grime built up. I tried washing and scrubing but it won't come off.`will regular alumnum polish and steel wool + elbow grease get this clean for me?
Yes, but just be careful on what type of steel wool you use. Don't use something too abrasive and scratch it up.
You might have heard of those Mothers Power *****?
Go to any of your local auto stores that sell car care products, and you'll find one. One of those attached to an electric drill and some aluminum polish and your wheel will look better than new.
=1 on the shout, gets the brake dust and road grime off pretty good. Also use a small scrub brush on the aluminum to get the dust or grime out ofit. Something like a scrub brush for pots/pans or a baby's bottle brush.
What? you mean just shout it out? LMAO Well if it helps why not,i used easy off to get oil off my heat shields! just be super careful not to get any - anywhere else like the black engine parts.
Originally Posted by 2007fxdc
Try spraying some shout stain remover on it - get the gel kind if you can so it will stay on better. Let it soak before scrubbing - it should help.
I had pretty good luck cleaning off brake dust with a Mr. Clean Magic Eraser. The texture of the wheel eats it up, so you'll only get one use out of it.
Joe K. suggested using Shout a few months ago and I tried it out, it works GREAT. I have to add, however, that my wheels were not built up with grime to the point something else would not have worked.
The more you rub it the shinier it gets though, so that is a plus if it takes you a while
