Wiring Frustrations - Ape Hangers
Old Apr 18, 2009 | 11:40 AM
JRK5892's Avatar
JRK5892
call me if you get stuck this weekend... cutting and soldering them is supid easy if you have the stuff... I do, ill give you a hand... if i recall you are local right?
Old Apr 18, 2009 | 04:05 PM
critter_catcher74's Avatar
critter_catcher74
Originally Posted by panic_fan
I have Z's with right angles in them and I used string to pull nylon weed-eater string through first. Taped all the wire crimps into a single bundle and then looped the nylon through that. Keep the bundle as short as possible or it won't be able to pivot through the bends. Use a separate piece of nylon hooked to the braided sheath and pull it through afterwards.
+1 on holding off on the malted beverages until afterwards. I've found my patience diminishes exponentially with each one I consume.
Didn't use any lube...ick.
Good luck.
I did pretty much the exact thing without lube only I used a length of 18ga wire instead of weed eater string. Also used no lube. I staggered the cuts on the wires to slim down the splice and protected the wires with a few wraps of electrical tape.
Old Apr 18, 2009 | 05:04 PM
jblank37's Avatar
jblank37
I have never tried this, but it is a thought. Take a small nut that will go through the hole where the wires will come out. Tie fishing line, the same number as you have wires to the nut and feed it through bars and have it drop out at the hole. Have the fishing line long enough to tie to each wire. A small piece of heat shrink or black tape should work over the tie point. Then feed each wire through one at a time. Like I say, just a thought.
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
TylerBoehm
Jun 11, 2014 02:14 AM
smokinfromshootin
Nov 20, 2010 09:01 PM
Dyna2007
Dec 27, 2009 07:34 PM
bobbsterkid7
Oct 12, 2007 12:25 PM
