Dyna Axle Size Question
Old May 5, 2006 | 10:08 PM
Randy Page's Avatar
Randy Page
Default Dyna Axle Size Question
When did HD change axle sizes?
I'm wondering if an 01 front end is same axle size as an 05.
Thanks for the help.
Randy
Old May 5, 2006 | 10:14 PM
06dynablack's Avatar
06dynablack
Default RE: Dyna Axle Size Question
dont know if the fronts been changed but the rear axle nut is metric on 06 now
Old May 5, 2006 | 11:00 PM
WgSkee's Avatar
WgSkee
Here's the axle info..
.. to the muscular 160mm rubber in back. On top of the new tough look, you’ll notice performance upgrades, too. Beginning with a whole new gearbox. The all-new 6-speed Cruise Drive™ transmission is ready to kick its legs out on the open road. The clutch takes less effort to pull, making all six gears even more satisfying. A new frame, new 1" front and rear axles, and a wide swingarm make handling tighter than ever. Also for 2006, you’ll find all Dyna 1450cc Big Twins equipped with consistently smooth-operating Electronic Fuel Injection (EFI) standard for the first time ever. You might find it hard to believe, but we did all this without compromising affordability. No one but Harley-Davidson® could ever take the factory custom to a place this good.
Old May 6, 2006 | 12:30 AM
parts guy's Avatar
parts guy
the rear axle nut on 06 is 1 1/8 not metric.
nick 06 bob
Old Jan 5, 2007 | 12:18 AM
malcolm06WG's Avatar
malcolm06WG
I just went to Lowe's and got an 1 1/8 socket to remove the rear axle nut. The socket fits but is a little loose. I don't know if that normal or if the nut is metric on an 2006 Wide Glide. Do you guys know for sure?
thanks
malcolm
Old Jan 5, 2007 | 01:43 AM
Naz_Man's Avatar
Naz_Man
Bet it's metric? My 05 has a 1" axle on front and a 3/4 or 7/8 on rear not sure ATM, Sleepy time !
Old Jan 5, 2007 | 04:52 AM
carltex's Avatar
carltex
I used a 1 1/8 socket on mine but I think it really takes a 28 mm socket. The 1 1/8 was a bit sloppy.
Old Jan 5, 2007 | 10:05 AM
murphdog's Avatar
murphdog
Since the original question was about front axle size, I believe the axle changed to 1" on Wide Glides in 2006 and on the narrow front end Dynas in 2004.
Old Jan 5, 2007 | 08:28 PM
piniongear's Avatar
piniongear
I'll ditto that Murph. The axle size went up to 1 inch in 2004 and newer. I have a 2003 Dyna (narrowglide front end )and it is the last year using the 3/4 inch axle....pg
tonyd2017
Jun 26, 2019 09:06 PM
Fennec
Jan 25, 2011 01:02 AM
Dynafrom818
Aug 24, 2010 02:44 PM
wadejesu
Feb 22, 2007 07:04 AM
parts guy
Apr 14, 2006 11:01 AM
