Problems with bar swap - Help...again
Old Apr 22, 2009 | 12:11 PM
coachstorms's Avatar
coachstorms
Default Problems with bar swap - Help...again
So my buddy got rid of the ugly stock bars on his rocker c and put on a 1.5" straight bar with 6" risers that have individual tops - looks great except that the bar/risers move around now - for example when you turn it to full lock out the risers and bar will still move a 1/4 inch or more past that, so when you bring the wheel back to straight the bars are mis-aligned. I took them apart, replaced the stock bushings with some urethane ones and reinstalled them...only to find out that it was still had the same problem. It was at this point that my buddy had to be put on suicide watch.
So what gives? I'm not that experienced but this seemed to be a pretty straight forward deal to be this much of a problem. Any help or advice is appreciated.
for those that helped yesterday, i got the switch fixed - there was an extra brass throttle ferrule bouncing around inside the housing.
Old Apr 22, 2009 | 12:18 PM
FUQUA's Avatar
FUQUA
Coach it sounds like you've done what you needed by replaceing the bushings are the studs on the risers the same size as the ones you took off ? Check the bushings on the studs without them on the bike they should fit tight. If not that could be the issue.........hope this helps.
Old Apr 22, 2009 | 05:04 PM
coachstorms
had it apart again and those fu**ers still move. If I can't get this resolved in the next day or so the run we were going to make up around the grand canyon will be shot...
Old Apr 22, 2009 | 06:23 PM
compgeek789's Avatar
compgeek789
Can you post a pic of the risers?
Old Apr 22, 2009 | 06:26 PM
jimw411's Avatar
jimw411
You need to swap out the stock rubber bushings with harder polyeurathane ones.
Old Apr 22, 2009 | 07:24 PM
coachstorms
I already did.
Old Apr 22, 2009 | 07:31 PM
coachstorms
Sorry, no pics but - the risers are Drag Specialties part#0602-0161. The tops are Drag Specialties part#0602-0157. The bar is a "big" buffalo bar, part#0601-0668. They are all buffalo products and the risers are supposedly made for that specific bar. Someone mentioned getting them pinned and someone else said to get a one-piece riser cover, any suggestions? [IMG]file:///C:/DOCUME%7E1/jjstorms/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
Old Apr 22, 2009 | 08:25 PM
ratt196635's Avatar
ratt196635
maybe your bolts that go into the risers are to long and not tighting up because they are bottomed out in the riser....just a thought
Old Apr 22, 2009 | 08:57 PM
thedonthere's Avatar
thedonthere
+1 on that
Old Apr 22, 2009 | 09:00 PM
Zacharia_11's Avatar
Zacharia_11
So the new bushings are tight on the studs, the risers are snug on the bushings, and the whole show is torqued down prior to installing the bars and your still have movement...? Hmmm. IMO It's really got to be one those things causing it.
Did you get the riser bolts they suggested on their website?
