removing front wheel
Old Apr 23, 2009 | 01:23 PM
fxdc8's Avatar
fxdc8
6th Gear
Default removing front wheel
Can't seem to get the slider cap screws loose , they are TIGHT. I may have stripped one already, not sure. Any tips on getting them off , are they metric? I may be using the wrong size. Help appreciated, thanks.
Old Apr 23, 2009 | 01:34 PM
thedonthere's Avatar
thedonthere
The front forks are Showa (jap) the cap screws you are having trouble with are 5mm. Also just for reference both the calipers are metruc as well. The bolt that hold the caliper to the fork are 10mm as are the bolts for the brake pads.
Old Apr 23, 2009 | 01:38 PM
fxdc8's Avatar
fxdc8
6th Gear
Thanks a lot for the info that could be the problem. I'll go get some more metric tools.
Old Apr 23, 2009 | 01:48 PM
JRK5892's Avatar
JRK5892
MEtric... also i hit them with PB blast for about 20 min first
robbyville
Apr 15, 2015 12:48 PM
DrO
Mar 19, 2012 06:15 PM
Jaymac3772
Oct 4, 2010 09:48 AM
SubZer0
Jan 21, 2007 06:42 PM
