Brake rotor bolts
This ain't rocket science & it isn't very techie stuff otherwise you surely wouldn't be taking your bike to the dealerships & letting their monkey's work on your bike.
You should be more worried about stripping out the threads in your aluminum wheel hub than worried you're "overstretching" or gonna break a steel bolt which is also most likely a grade 8.
BTW tlb you said you were neither an engineer nor a mechanic & that you've pulled lots of hardened bolts that were stretched. How much had they stretched, as in what were the before & after measurements, & what measuring device did you use?
I had a friend whose pulley bolts, one of them, did back out on a ride because they were not loctited. We loctited them & tightened them as much as possible at a gas station & he's never had a problem since. Believe me, when that one bolt started backing out he knew it. Pulleys don't just come flying off.
As I said before, "Some of you guys think WAAAY too much & end up WAAAY over engineering you motorcycles in your own mind. " If it makes you feel better than good on you.
fastener backing out because of a less than qualified dealer tech installing the parts??? Some folks on here are funny about the things they profess to know about... BTW a fastener is only permanently stretched if overtorqued or turned to its yield point... This is done by manufacturers for a number of reasons which I dont have time to explain but I believe reuse of these pulley and rotor bolts is fine based on inspection and reapplication of loc-tite.... Also I would suspect the aluminum hub threads would stretch and deform first before bolt failure??????.......................tim
Also as stated before, I often wonder what percentage of that recommendation is for profit and what part is for safety.
I just do not understand why someone would risk the cost of a new rotor, the rear wheel, swingarm and possible death, to save less than 10 bucks.
But hey, here's your sign.
Ace hardware carries a full set of bolts. I will not use chromed bolts, but I will put chromed caps on the bolts.
All of these thoughts brought to you by:
A. 40 years of working on my own vehicles.
B. A healthy does of common sense (thank you dad).
C. Free will.
D. Living in a free country.
I want to worry about things I can't control.... not things I can control.
who ever reads this may do as they wish
