Fork Clunk
Old Apr 25, 2009 | 09:30 AM
grumpy56's Avatar
grumpy56
Default Fork Clunk
Strange front end noise has appeared lately on my 06 SG (6000 miles). Sounds like the noise old springs in cars used to make when you would bounce on the bumper. Any thoughts? Thanks.
Old Apr 25, 2009 | 10:12 AM
gregbenner's Avatar
gregbenner
I'd check the fallaway (steering head bearings) first...might be the most likely.
If the springs are too weak they could be making noise when the tubes are fully extended, or could be twisting and hitting the sides.
Also, when the front brake is applied, the pad can potentially twist and knock against the caliper....will sound like its a "fork" issue.
Old Apr 25, 2009 | 11:01 AM
sporty79's Avatar
sporty79
You are experiencing the all too common "front end clunk".
Read this:
https://www.hdforums.com/forum/dyna-...e-process.html
Old Apr 25, 2009 | 12:59 PM
grumpy56's Avatar
grumpy56
Thanks for the info.
bossman605
Jun 10, 2008 11:21 AM
Arvis
May 7, 2008 09:02 AM
sleepyjim
Sep 9, 2007 08:42 AM
hawker
Jul 30, 2007 11:53 AM
Broken Leg Rider
Aug 1, 2006 04:38 PM
