Fork Oil question
Old Apr 28, 2009 | 07:08 PM
MZBuckeye's Avatar
MZBuckeye
Originally Posted by seniorsuperglideE8
Hey Buckeye, when you do the next fork oil change install the forkcaps with the screw in the top of the cap. Remove the drain screw, remove the forkcap screw. Drain oil, install drain screw, pour required amount of oil in fork tube thru the cap screw hole then install screw. No floor jacks, no screwing with springs. Badda boom, Badda bing your are done.
I'm not sure I understand, you mean drill and tap a hole in the the screw caps, and install a new screw in the caps? So I'd have drain screws and fill screws? If that's what you mean, that is a good idea. I'm not sure I'd trust myself to tap the caps, but I know someone who probably can.
Old May 1, 2009 | 12:39 PM
El Jinete Fantasma's Avatar
El Jinete Fantasma
I did a search because I was confused about the 5K service check-up on the Harley web site. The way it's laid out, I initially thought they were saying to replace it every 5K miles, but the note at the bottom says "Disassemble, lubricate and inspect every 50K miles."
Old May 1, 2009 | 06:26 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Actually you can purchase these fork caps thru most aftermarket vendors. I got mine thru J&P Cycles. Search their site under forks category. Just make sure you have the front end supported and all the tins covered. Also don't have you head directly over the fork caps when removing them. Do one fork tube at a time.
Old May 1, 2009 | 08:07 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
...and get a helper; one to hold 50-75 lbs of down-force on those caps while you unscrew 'em. Not as many threads as you'd think, also...be ready!
Old May 1, 2009 | 08:20 PM
SC-Longhair's Avatar
SC-Longhair
I unscrewed and screwed the caps in all by my lonesome today. Not that bad at all. My name is not Arnold (schwarzenegger) either.
Old May 2, 2009 | 08:37 AM
MZBuckeye's Avatar
MZBuckeye
Yeah I did mine solo too. Taking them off was no biggie with the socket, but putting them back on was definitely a real bitch.
DON7245
Milwaukee Eight (M8)
Oct 17, 2017 12:49 PM
Bbbadboy
Apr 6, 2014 08:39 AM
albngore
Dec 2, 2010 01:35 PM
hpfatboy
Oct 19, 2009 10:34 AM
nb472
May 14, 2008 07:25 AM
