turn it off and on during riding
Old May 4, 2009 | 03:45 PM
mavi's Avatar
mavi
5th Gear
Thanks frog13, I am not young but surely so dumb...It is exactly what happened here at my end. I now have to discover which cylinder had the problem, then try to take the valve off. Thank you all.
Old May 4, 2009 | 04:09 PM
duoglider's Avatar
duoglider
you ought to track down the fool who suggested you do that and explode some dollar bills out of his wallet.
Old May 4, 2009 | 05:56 PM
raporte's Avatar
raporte
Take 5 tablespoons of baking soda and add it to your gas tank. It will clear it up soon. If it doesn't, the piston springs are loose and can be realigned by adding some Hersheys syrup to the engine oil (about 1 1/2 cups) and taking it out for a spirited romp. Case closed.....
Old May 4, 2009 | 09:19 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Li'l "SPUNKY" tonite are we, Ric???
Putting my $$ on the exhaust valve. Go one step further, it very well could have 'contacted' the piston. HOPEFULLY, jus' a "ding" and NOT a "BANG". BUT to be honest with ya, have seen busted pistons, bent rods, and cracked heads. So, as posted, NOT a good thang.
Even tho MANY have learned, MOST learned younger, THAT'S the ONLY difference. Let 'em 'steam' at ya. Been there, Done that.
My hat's off to ya, for comin' on here and postin'.
Show your Man Card at the bar for a FREE round.
Old May 4, 2009 | 09:33 PM
will2002's Avatar
will2002
Well,-----It took guts to post this little story, I would think.
Old May 4, 2009 | 11:00 PM
jandlcars's Avatar
jandlcars
From: NOMAD Milton FL Now Originaly From San Rafael CA
see if u can get a compreation gague
pull plugs put gague in fromt spinn engine about 8 rev then do the back that shoukd tell ya what cyl it is before tare dawn
then extract his wallet for repair help
Old May 4, 2009 | 11:15 PM
gunner11's Avatar
gunner11
Don't listen to stupid people, it makes you just like them. Why would you even want to do that is beyond me.
Old May 4, 2009 | 11:34 PM
oppirs's Avatar
oppirs
foret it
Old May 5, 2009 | 01:43 AM
Other Sheep's Avatar
Other Sheep
I've seen top fuel dragsters do that but the explosion they made was probably bigger than yours.
Old May 5, 2009 | 01:51 AM
billyp326's Avatar
billyp326
I'm not quite sure how to respond to this thread but man I got to give it to ya for having the set of ***** to share your mistake with us... Good luck with it and let us know how things turn out
