Dynamometer Performance Tuning Necessary?
Old May 4, 2009 | 07:36 PM
Ciphex's Avatar
Ciphex
Default Dynamometer Performance Tuning Necessary?
I just picked up a '09 FXDF in denim black with the Big Breather, SE Race Tuner, and V&H Big Radius 2/2. Is it really necessary to dyna tune this or can I save myself $500?
Old May 4, 2009 | 07:39 PM
Ciphex's Avatar
Ciphex
I wanted to reference another discussion on the going rate for a dyno tune, which seems to be about $250-300.
https://www.hdforums.com/forum/touri...dyno-tune.html
The nearest tuning shop is in Gladstone, OR and they're talking 3.5hrs of labor at $100/hr for a total of $425.... ouch!
Old May 4, 2009 | 07:43 PM
JRK5892's Avatar
JRK5892
no... you can use your SERT to get it right or at least as close to right as you need... you only really need to dyno when you change the motor... cams, heads, etc.... some still dyno with exhaust and intake... i did not ahve the GRIP to do it so Eric came out to help me tune mine in...
all done on the sert... i can snap loose my back tire though 3 gears on a stock 88, with pipes and intake... and tach shifting, little to no pop... runs tops!
Old May 4, 2009 | 08:05 PM
Ciphex's Avatar
Ciphex
Very good to hear, thank's for the insight. Was there anything Eric did or noted about the tuning process worth knowing before I dive in?
Steel Wheels
May 14, 2015 09:47 PM
wildwind
Nov 21, 2010 11:06 PM
6165hd
Mar 16, 2009 08:11 AM
Paradox
38
Jan 27, 2008 01:07 AM
santino
Mar 28, 2006 01:03 PM
