Dyno Help
Old Mar 24, 2006 | 05:41 PM
santino's Avatar
santino
2nd Gear
Default Dyno Help
Just got a call from my tuner for a SE build. Only got 96.4 hp and 89.8 TQ with a 2006 Dyna, 1550, HTCC Ported, 50MM TB, 251 cam, SERT, and LSR 2-1 exhaust. I know it can do better than that. Any recomendations?
Old Mar 24, 2006 | 10:54 PM
SEFXDI's Avatar
SEFXDI
1st Gear
Default RE: Dyno Help
Your right it should have done better.... the 50MM TB was a bit much, but it still should have dynoed out over 100 hp. I've got a friend with a 05 ultra classic, he went with the SE pro heads and cast piston 95" set up with the 257 cams which was a bad choise for the dur on his bike and he was running drag pipes which hurts more than anything and he still got 103 hp, it did improve when he installed the thunder monster power baffles from bigcitythunder.com....it also depends on how much time the tech spends on the tuner part on the dyno. Some techs will just slap it on and get onto the next job, it's not their money or bike, some tech take pride in getting their customers the most for their money and so they spend a little more time and produce a lot more.
Old Mar 24, 2006 | 11:03 PM
JonHanna's Avatar
JonHanna
what brand of tune are you using? H-D stage 2 download, SERT or something else? Are they tuning it on a dyno or just running it?
Old Mar 25, 2006 | 12:24 AM
santino's Avatar
santino
2nd Gear
They tuned it on the dyno while running the SERT program and adjusting the map. I don't have the dyno sheet yet but will get it on Monday. There's gotta be more to this than what has been done so far.
Old Mar 28, 2006 | 01:01 AM
SEFXDI's Avatar
SEFXDI
1st Gear
Been doing some further checking and some of the dealers will just do an intial program that only goes up to 3000 rpm until you get 500 miles break-in on the new parts and then you take it back and PAY to have it reprogramed to get the best results, or re dynoed. after break-in they will dyno it up to what ever rpm your rev limit is set for.
Old Mar 28, 2006 | 01:03 PM
DyNaBoB's Avatar
DyNaBoB
pffffffttttt
floridamk
Exhaust System Topics
Apr 29, 2013 08:12 PM
chieffieldeng
Jun 3, 2007 09:22 PM
MiniMe
May 30, 2007 08:02 PM
KBFXDLI
Jun 1, 2006 07:38 AM
Jezcruzen
Jan 8, 2006 12:31 PM
