A little help with minor problem - brake side foot peg
Old May 14, 2009 | 02:14 PM
caserx's Avatar
caserx
6th Gear
Default A little help with minor problem - brake side foot peg
I have had my heel rests on for about a week. Last night on my way home from work the brake side peg+heel rest pivoted towards the ground. I can twist it back up but as soon as i put some pressure on the heel rest it pivots back down. I have included pics so you can see what I am talking about. Is there anything I can do to prevent this from happening?
I could probably pivot the shifter side heel rest down by rotating the heel rest on to different splines but I dont think the set screw really has that much play. Plus I think it is pretty comfortable as is.
Attached Thumbnails A little help with minor problem - brake side foot peg-p1010830.jpg   A little help with minor problem - brake side foot peg-p1010831.jpg
Old May 14, 2009 | 02:20 PM
r00k's Avatar
r00k
How does that heel rest connect to the mounting bracket?
It looks like its rotating there, loctite or a lock washer might help but some pics of how it assembles would really help.
Old May 14, 2009 | 02:21 PM
SC-Longhair's Avatar
SC-Longhair
Have you taken it apart to see why it's loose?
Old May 14, 2009 | 03:03 PM
rounder's Avatar
rounder
Pull off the peg from the forward control. There is a torx bolt holding the brake assembly together. Tighten it up. Tighten very tight.
Refrain from putting all your weight on the stirrup.
Old May 14, 2009 | 03:09 PM
Goddahavit's Avatar
Goddahavit
Ohhh who makes those, i've been looking for a black set!!!
Info if you can please..
Eric
Old May 14, 2009 | 03:40 PM
caserx's Avatar
caserx
6th Gear
I think that will do it. I remember seeing that torx bolt when I was putting them on. Thanks for your help.
Old May 14, 2009 | 03:47 PM
caserx's Avatar
caserx
6th Gear
Eric
I found a good deal on a chrome set and then had them powdercoated. Thought about just painting them myself but asked a local powdercoater and he did them for 20 bucks.
Old May 14, 2009 | 04:02 PM
Border Cop's Avatar
Border Cop
I have the same problem, it's the peg mount that is loose. You need a long torx bit to get at it though, a standard one will not fit. Red loctite maybe??
Those heel rests look identical to my HD ones except mine are chrome.
TheGoldy
11
Oct 28, 2017 06:43 PM
CW4_131A
Sep 21, 2015 11:32 AM
bbqbrisket
Aug 12, 2013 12:48 PM
dogzzz1
Apr 4, 2008 11:15 AM
LAXRoadKing
Apr 19, 2007 08:33 PM
