Poly Riser Bushings -- Wow.
Old May 14, 2009 | 04:33 PM
r00k's Avatar
r00k
Default Poly Riser Bushings -- Wow.
About a week ago I swapped my rubber riser bushings with Polyurethane bushings. The difference is amazing, my mirrors are usable and my hands feel better after a long ride.
Talk about a great mod for under $13.
Old May 14, 2009 | 04:35 PM
Stanger's Avatar
Stanger
Yes sir, I know the feeling. Especially if you have apes!
Old May 14, 2009 | 04:48 PM
Centerline's Avatar
Centerline
How about that, a parts guy at my local HD shop was telling me just about exactly that, this afternoon as I placed an order for some new 6" HD up and back risers for 1.25" bars.
Old May 14, 2009 | 06:17 PM
jsbridgew's Avatar
jsbridgew
I actually went in the opposite direction... I had polys and all i felt was vibration...couldn't even see out the mirrors at idle... ended up shaking my apes loose, actually
swapped back out to rubber and problems solved
Old May 14, 2009 | 06:41 PM
jaysonL's Avatar
jaysonL
I had the same issues with the rubber bushings.... Turned out when the dealership mounted the bars and risers, they over torqued the risers and stripped the threads in the not allowing them to tighten up properly. I found it when I replaced the rubber bushings. I re-tapped the threads and torqued the risers to spec. and problem solved ! I love the feel of the poly bushings, now that the problem is solved.
Old May 14, 2009 | 07:05 PM
Baeseman1's Avatar
Baeseman1
I swapped out my rubbers this winter for poly and didn't notice any difference. Actually, I forgot about it until I read your post...
Old May 14, 2009 | 08:23 PM
r00k's Avatar
r00k
I think its a lot more noticeable when you have apes, when I push my bike around I don't feel the give anymore.
Old May 14, 2009 | 08:34 PM
DynaDan's Avatar
DynaDan
rOOk, that was the biggest difference that I noticed.
Old May 14, 2009 | 10:22 PM
joe.1955's Avatar
joe.1955
Same here, the biggest plus is losing the forward and back play that the rubber bushings had.
The new bushings transmit more vibration, but don't have any "sloppiness" to them.
user 46092
Jul 24, 2016 07:30 PM
bigjosh42
Jun 11, 2014 01:33 PM
decencyxdefied
Apr 30, 2012 10:28 AM
harleyheaven
Apr 5, 2011 07:37 AM
05 HD Deluxe
Oct 29, 2008 11:05 AM
