06 owners manual wrong
Old May 11, 2006 | 01:40 PM
jkenosh's Avatar
jkenosh
Default 06 owners manual wrong
I have a 06 dyna and the oil drain and transmission drain pictures in the owners manual are backwards, i got my bike in sept 05, did they change the newer 06 manuals?
Old May 11, 2006 | 01:42 PM
phreak's Avatar
phreak
Default RE: 06 owners manual wrong
I phound that one out the hard way myself. Did you get a copy of the service manual yet? It shows the correct locations.
Old May 11, 2006 | 01:48 PM
sws1's Avatar
sws1
My '06 manual is correct. Bike was built in October. But then again, I bought it in March, so dealer may have simply replaced the manual.
Old May 11, 2006 | 03:29 PM
jkenosh's Avatar
jkenosh
yours shows the oil drain on the left side by the primary drain and the trans directly underneath?
Old May 11, 2006 | 03:51 PM
sws1's Avatar
sws1
ORIGINAL: jkenosh
Yes
Old May 27, 2006 | 09:26 AM
Gummiente's Avatar
Gummiente
Bought my FXDI last October and had the dealer do the first two services. Did an oil change myself the other day and noticed the error in the manual. Called my dealer, they weren't aware of it. [&:]
Anyway, it's a good thing my previous bike was an '04 FLHT with the same basic TC88 motor, otherwise I really would have been unsure and probably changed the trans fluid as well even though it didn't need it.
Old Jul 1, 2006 | 10:46 AM
johnpiech's Avatar
johnpiech
Default Oil change 06 Dyna - Is owners manual wrong
I'm looking at the manual for the 06 Dyna I have. It shows the oil change plug as on the left side of the engine, kickstand side, oriented horizontally. I see the second drain plug on the other side of the engine which is oriented vertically.
MY FXDI35 was delivered to dealer in November, but not to me until March. Can I assume I have the updated and correct owner's manual. Can someone confirm the 06 Dyna drain plug is on the left side of the engine (kickstand side) oriented horizontally?
I have 600 miles on it now - going to do dealer service at 1200 - so I'm skipping the filter. Does anyone know what the fill capacity is with filter unchanged vs with new filter? I also have the 06 Dyna oil cooler; can I assume it will drain and require and reguire an extra 1/2 quart vs a non oil cooler bike?
Thanks
Old Jul 5, 2006 | 12:50 PM
jkenosh's Avatar
jkenosh
Default RE: Oil change 06 Dyna - Is owners manual wrong
the oil drain is on the left side and its horizontial the tranny drain is directly underneath.
Old Jul 5, 2006 | 01:57 PM
HOGRIDA_06's Avatar
HOGRIDA_06
My service man. and owners man. both show the plug in the right spot.
Old Jul 5, 2006 | 09:02 PM
madcitycustom's Avatar
madcitycustom
You're changing your oil, but not the oil filter? Did I read that correctly?
