Leaky oil plug
Old May 18, 2009 | 03:29 PM
George D's Avatar
George D
Default Leaky oil plug
I started leaking oil from my oil plug. When I pulled the plug I discovered that the local shop that changed my oil last time must have screwed the threads up because the plug had epoxy all over the head of the bolt and the threads had been taped. So I re-threaded the hole with a pipe tap and put the correct size bolt in the hole. It was good for about a week. One of the guys at work suggested I use a helicoil kit to fix it. Does anyone have any experience using one of these kits in the oil pan and did it work?
Old May 18, 2009 | 03:37 PM
rounder's Avatar
rounder
helicoils work great. i had to use 1 for my breather on the front cyl.
Old May 18, 2009 | 03:55 PM
BULLDOG88's Avatar
BULLDOG88
Is the rubber o ring missing.
It sounds like you still need a repair, but a missing o ring will produce a leak.
Old May 18, 2009 | 10:08 PM
06dynablack's Avatar
06dynablack
so did you thank them?
jtsteiert
Mar 3, 2014 08:36 AM
aces&8s
Exhaust System Topics
11
Sep 9, 2013 04:42 PM
Pagman
Jun 21, 2012 07:25 PM
DMetcalf
Aug 5, 2009 01:07 PM
hoppypy50680
Sep 9, 2007 01:45 AM
