Ran my handle bar wiring inside.
Old May 24, 2009 | 12:57 PM
red1100cc's Avatar
red1100cc
Talking yea what Vic said
[quote=As long as you stagger the solder joints, and shrink wrap them I don't see a problem with it.[/quote]
i had to cut and add wire to get mine long enough, also had to mechine a few holes to run them through. there may not be any "right way" to do it, but there is a wrong way. never never use those crimp style connectors to put your wires back together. always tin then solder them together. i used shrink wrap over each wire then shrink wrapped the whole bundle together. so far so good.
Old May 24, 2009 | 06:14 PM
Kaycee's Avatar
Kaycee
Man I didn't mean to ruffle ya-alls feathers,after I posted I re-read my post and thought I would get shot at.It was just my prefered way all in all it sure cleaned up the bars.At least I run the right oil
Old May 24, 2009 | 08:16 PM
RudeDog's Avatar
RudeDog
Nope, no feathers ruffled here.
I actually used a type of shrink tube from my other job, it has a sealant inside that shrinks and seals the connection when heated. Not sure of the name of it but it is the greatest thing for a wet atmosphere application.
Did you guys leave the black plastic wiring cover over the wiring when you strung it through the bars? I figured I'd leave it on just as an extra bumper zone to protect the wiring.
Old May 24, 2009 | 08:33 PM
archergodwin's Avatar
archergodwin
I disassembled the connectors, but still cut and spliced 8" into my wires. I did all my solder joints at the same place, and had no problem (fatty bars). Heat shrink on each individual wire, and then another larger over them all.
I left the original black covering over most of the wires, but where they exit the bars I ran some braided nylon wire loom over them, between the bars and the backbone.
Old May 24, 2009 | 11:38 PM
jcmusic's Avatar
jcmusic
Good pic's way too cool, thanks for the pic's. How did you put the hole in the handlebars?
Jay
jmaxx24
Dec 8, 2012 05:55 PM
solracg
Aug 30, 2012 07:42 AM
1931jamesw
Aug 21, 2011 04:01 PM
georgiabiker
Mar 19, 2008 06:57 PM
bobbsterkid7
Oct 12, 2007 12:25 PM
