High flow Air filter
Old May 14, 2006 | 02:16 AM
rj164's Avatar
rj164
Default High flow Air filter
I have a question to anyone who replace the stock air filter, with the High flow air filter, the canster at the bottom of the bike, did you removed it, I was told I could since the hook up is not connected to the stock, which is right, but I see on the other side there are two hose running to the tank? how do you take care of this, plug the lines of what???
Old May 14, 2006 | 02:57 AM
mcurry5's Avatar
mcurry5
Default RE: High flow Air filter
huh???
Old May 14, 2006 | 02:59 AM
WildBill76's Avatar
WildBill76
Leave it on. You must live in California. C.A.R.B. requies it. If you get pulled over, and the CHIP notices it missing, you will get a real big fine and jail time. It is a fuel vapor canister.
Old May 14, 2006 | 03:17 AM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: rj164
Link
Old May 14, 2006 | 02:53 PM
rj164's Avatar
rj164
Thanks for the information, some of the chapter guys ask why don;t I removed the canster, and talk to the service guys, since I change out the pipes and air filter it comes that I can do it or not ?
Old May 15, 2006 | 12:20 AM
FREEFALL's Avatar
FREEFALL
When I replaced mine (intake/exhaust) I ripped off all of that California CRAP. I just did a ride with my local HOG chapter (Biggs) and nobody has that CRAP on their bikes. Everyone I know has removed it. I guess if I get stopped and thrown in jail I will know why but have not seen it happen yet.
S/F
TOP
Old May 15, 2006 | 03:04 AM
rj164's Avatar
rj164
Well Top, It's off the bike
[IMG]local://upfiles/10881/535E8D84857D46698838D65BF7C959A7.jpg[/IMG]
Old May 15, 2006 | 11:39 PM
jimw411's Avatar
jimw411
The evap canister is easy to remove. The really big line is just tucked under the tank and isn't connected to anything, The 2 small vacuum line on the the other side of the canister will be marked "tank" "carb" or something along those lines. Plug the one that says carb and leave the one that says tank open. When removing the bracket that holds on the canister, lossen both bolts but only remove one at a time since these bolts hold on the bottom motor mount.
Old May 16, 2006 | 12:59 PM
rj164's Avatar
rj164
Thanks for all the information
Old May 16, 2006 | 09:26 PM
FREEFALL's Avatar
FREEFALL
ORIGINAL: rj164
rj164,
Bike looks good. How do you like the forward controls? Are they HD? I'm looking to do mine next month.
S/F
TOP
