Derby Cover...Loctite or not
Old Jun 1, 2009 | 01:26 PM
SuperglideKen's Avatar
SuperglideKen
Default Derby Cover...Loctite or not
Hey guys, The weather has been pretty good lately and have got in a few miles. Once it turns Swellterring Hot I'm going to pull her back in the basement where my beer will stay cool. I plan on changing out the HD Syn 3 that the Dealer put in each hole to a better choice of oil. I do have the manual and I'm sure it will say but Do you guys use Loctite on the 5 Torx screws and anything else I should know when changing out all three holes. Thanks for the help.
Attached Thumbnails Derby Cover...Loctite or not-derby2.jpg   Derby Cover...Loctite or not-super.jpg
Old Jun 1, 2009 | 01:50 PM
paul s's Avatar
paul s
New gasket for the derby cover and new O-rings for the drain plugs. I don't loctite the derby cover screws, I didn't see it being used in the book either.
Old Jun 1, 2009 | 01:53 PM
JRK5892's Avatar
JRK5892
yes loc tite the derby cover! if not they will vibrate out and leak... you only need new gaskets if the original one is torn up... they are rubber man and last a long time, i replace my o rings ever 2 changes... i have done over 6 oil changes on my scoot and have used the same gasket without any problem. (granted mine is made to work wiht my custom derby cover... but never the less. if it is still in good shape you are fine)
Old Jun 1, 2009 | 01:58 PM
SuperglideKen
Thanks for the quick replys.
Joe, I hear about a lot of guys having trouble with the Torx screws and stripping them out. Was it you who suggested a while back to take a center punch and strike the screw once and it then will come out, if not do you think it would hurt anything to do this.
Old Jun 1, 2009 | 02:19 PM
thedonthere's Avatar
thedonthere
I have never used loctite on my derby cover, I just torque it to spec, over 3 years now, many oil changes never a problem.
Old Jun 1, 2009 | 02:22 PM
xxxflhrci's Avatar
xxxflhrci
No loctite needed, IMO. Getting them out is tough enough sometimes, no need to compound the problem. In 75k miles, mine have never vibrated loose and/or leaked. I still have the original quad-ring (gasket).
Old Jun 1, 2009 | 02:29 PM
paul s's Avatar
paul s
I just checked the torque on mine and still holding at 100"s.
Old Jun 1, 2009 | 02:43 PM
cstolp's Avatar
cstolp
Use a hand held impact driver.
Old Jun 1, 2009 | 02:52 PM
shimmon's Avatar
shimmon
if you use loctite... use a lil dab of blue. you wont have any problem removing blue loctite if you use it sparingly. now that red ****... thats a different story!
Old Jun 1, 2009 | 02:55 PM
JRK5892's Avatar
JRK5892
use a punch yes... hell i do that with all the torques heads!
