We use avgas to winterize boats and for other long term storage. It has no ethanol and does not turn to varnish as it evaporates. We don't fill the tanks with it, but just run it through the fuel system. No known benefits for stock engines that are run on a regular basis. The guy who runs the airport says it makes air cooled engines run hot (temp. wise). ???
dude is not possible that gas to make your engine to run hot!if something is gonna run colder,low compression high octane = cold run last performance,actually you gonna loos HP if your bike is not tuned for it.
to take advantage of high octane gas you must have high compression engine and to run more timing.
One guy that runs it has an old Shovelhead. If it's leaded I'm sure it's a great gas for his valves. The other has an '07 96" and runs it on every fill up, the other an 88", I might step back and see what happens there.
the higher the octane the fuel is the longer it burns for in the chamber/cylinder thats why you you can advance the timing more with higher octane..also i might be wrong but it should run cooler if the engine is set up right
you are exactly right.
high octane burns slower
low octane burns faster and hotter.
that is why when you have spark knock you run high octane gas to stop the pre ignition in the combustion chamber.
I have 10.5.1 pistons in my warrior and when was really hot out she spark knock on 93 pump gas but she run GREAT on that 100 leaded gas I ust to love to run that gas in my warrior,It was a lots of fun,and smell is lovely from the exhaust.
As was previously mentioned, if the '07 has a PCIII with O2 sensor replacements, then it won't really matter.
It might be great for valve seats but it's hell on spark plugs. Lead is corrosive. It's not good in any way for modern engines. And it wasn't that great for old ones. One of the reasons modern engines commonly run well over 100,000 miles with no major work is the lack of lead in gas.
I normally dump Shell 93 in it, and every 4 or 5 fills ups drop some octane booster in. When I saw the octane rating on AV gas I was hooked. Now that I see it could be harmful I'll stick to my old method.
hold a sample up to something white. If it is light blue, it is 100LL (low lead)
don't be fooled by the "low" part. It has plenty, believe me. And don't waste your time with it. I have not even read the thread yet and I am sure you have been told a thousand times by now it won't help you. It could harm your o2 sensors as well if your bike has them.
