AV Gas
Old Jun 7, 2009 | 06:36 PM
  #31
screamin 110's Avatar
screamin 110
AV Gas
is low lead fuel with oxy added. It also has a VERY slow burn rate that also helps keep the engine warm. Planes operate at a MUCH lower temp and a MUCH higher elevation and that is what Av gas was made for.
IT WILL NOT HELP A STOCK ENGINES HP!!! AND IT WILL NOT HELP A HIGH RPM ENGINE BUILD HP!!!!
I build race engine for a living Moto Headz Racing.
Old Jun 8, 2009 | 11:04 AM
  #32
richdeerht's Avatar
richdeerht
The manufacturers of piston aircraft engines are working very hard to get their engines to run on 93 octane fuel, which they call "mogas".
Aircraft engines compensare for higher altitude by manually leaning out the mixture.
Unless your bike has really high compression, or you have pinging problems, avgas won't help.
Old Jun 8, 2009 | 11:34 AM
  #33
Rider57's Avatar
Rider57
Originally Posted by speedjunkie
W........T........F????????? Rider57, are you drunk or high? That made NO sense!
Filled both wings (tops across) thats what it costs me. Baron with IO470's
100LL is blue, 110 is clear (no Lead). White exhaust is a very, very lean indicator. And there is no ethanol in any avgas.
Been flying since I was licensed at 17 in Alaska.
Old Jun 8, 2009 | 09:11 PM
  #34
speedjunkie's Avatar
speedjunkie
That I understand! I'm used to seeing a little gray on the exhaust tip tho. C177 pipeline patrol!
Someone else mention mogas. That's acutally automotive gas, 87 octane. You have to have a STC to run it.
Mike
Old Jun 9, 2009 | 08:48 AM
  #35
doublenaughtspy's Avatar
doublenaughtspy
You make the most power with gas that has the lowest octane that your bike can handle without detonation. All octane measures is the ability to withstand predetonation. If your bike doesn't knock or ping on regular, you're just throwing $$$ away on higher octanes. Any good tuner will tell you to run the lowest octane you can that doesn't cause knocking. Anything more is a waste of $$$ and your performance won't be any better. Keep in mind tho that you should run whatever the manufacturer recommends and no more - for example, you can get a car to run on lower octane fuel without detonation because the engine has knock sensors and will retard the timing to compensate = less power. So, if your bike calls for 91octane, that's what you should run. Anything less or more will hurt performance.
Old Jun 9, 2009 | 09:54 AM
  #36
jhmp's Avatar
jhmp
I run it in my bikes from the early 70's. They love it!!
beerun
Road Trips
17
May 30, 2010 09:19 PM
oley55
Mar 5, 2010 03:33 PM
Icepickvic
Jul 17, 2006 12:45 PM
Wolf
Oct 25, 2005 09:07 PM
SKJOLD
Apr 21, 2005 01:47 PM
