This is how I did it on my Fat Boy front. I don't see why it wouldn't work on the Dyna. I just went out in the garage to check. I thought of this all by myself when I was trying to install Progressives and there was no way that I was goin' push that cap on the same way as I have always done my dirt bikes.
Slide the fork tube about half way between the upper and lower tree. Tighten lower tree pinch bolts. Use a 2x4 for leverage against the upper tree. You may need to ajust how far up the top of your tube is for the best contact between cap and 2by.
Got it on last night. Went to the local auto store and got a 35mm socket (1-3/8 would have worked too but they didn't have the one I needed). It was a chore but got it on there.
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I enlisted help when I was doing mine. Had bro #3 hold down-force on the cap thru a large dowel, and I swung a 12" Crescent to get the cap started. Whatever method you choose, don't be a hero; enlist help.
I put mine in the trees and used a socket with a t-shirt piece between the socket and the "bolt" and wrapped the rest around the socket to keep from tearing up my hand when I pressed down.
