oil leak
Old Jul 9, 2009 | 02:48 PM
jfm5's Avatar
jfm5
Unhappy oil leak
hi all, I have just noticed a oil leak from where the two wires leave the left hand side of the engine to the voltage regulator it looks like a simple rubber bung with the wires coming from the middle. it looks like i may need to replace this bung is this a big job if thats what i need to do. ho its a 02 wideglide thanks trev
Old Jul 9, 2009 | 03:04 PM
maddghost's Avatar
maddghost
Have you tried wiping it to see if it comes back?,is the bolt tight? or can it be turned by hand?
Old Jul 9, 2009 | 03:50 PM
Arcane's Avatar
Arcane
If that is the left side as you are sitting on the bike, then it sounds like the wires that connect the stator to the regulator. I am pretty sure that the rubber plug is molded on to the wires or at least it is on my 06 WG, the only difference is that mine has three wires. Whether the plug is replaceable or even the entire set of wires and plug is replaceable I do not know. I recently replaced my stator and the wires look as if they might be soldered to the stator coils. You cannot really see the connection well enough to tell and the install instructions treat them as though they are not meant to be removed from the stator. As madghost suggested, try to clean the area and see if the oil returns.
Runamuk13
May 4, 2021 06:05 PM
EL GRINGO
Electrical/Lighting/Alarm
Apr 6, 2015 12:39 PM
xMPRx
EVO
11
Apr 7, 2012 10:26 PM
I8SMK4U
EVO
Apr 4, 2009 08:47 PM
Square Dude
Oil Archive (no new posts)
Oct 26, 2005 12:28 AM
