09 Fatbob Clunk/Shudder
Old Jul 11, 2009 | 11:28 AM
fatbob_chris's Avatar
fatbob_chris
Default 09 Fatbob Clunk/Shudder
Hi all! Im new to the forum. I have an 09 fatbob with 1,500 miles. Around 900 miles or so i started noticing a shudder/clunking feeling in the forward controls (pegs) when using the rear brake to slow down. I can also feel this sometimes on washboard roads, the bumps of them will cause it without the brake even on.. It even worse when going down a bumping hill with the rear brake on. I asked about it on my 1,000 mile service and they couldnt feel anything abnormal..
I checked the front and rear motor mount tightness and they were pretty good.. out of ideas.. It doesnt do it all the time.. it seems like it does it the first couple stop after the engine has been started then goes aways for a bit.. I put 40lbs of air in the rear tire and it has helped some its seems..
really, really, lost here guys..
Thank you in advance for any comments.
Old Jul 11, 2009 | 01:00 PM
wilcher's Avatar
wilcher
what kind of pegs? Some pegs tighten on the end so you can adjust them. Just a thought.
Old Jul 12, 2009 | 07:59 AM
USA1HD1's Avatar
USA1HD1
Welcome to the forum & the Dyna family.
I traded in my 08 Nightster this spring it kinda did the same thing. The dealership called me on my way home with my new bike & ask if I ever had the swingarm off I said never a reason why.
They said it road like **** with all the shimmy in the back so they pulled the wheel and found the swingarm bushing was trashed .
This was fixed & paid for by M.O company still only a year old bike ya might look into this idea if nothing else works out.
Goodluck Ride Long N Safe...
Old Jul 12, 2009 | 11:41 AM
archergodwin's Avatar
archergodwin
Might want to have the dealer (under warranty...) check your front end for correct fall-away and your steering neck nut/washer for correct torque.
Other than that, my bike shudders a bit when coming to a stop sometimes... I think most Dynas do.
Old Jul 12, 2009 | 03:33 PM
fatbob_chris
archer, do you feel knocking in your forward controls when using the rear brake sometimes or over bumps?
Old Jul 12, 2009 | 03:36 PM
archergodwin
Not so much knocking, as in a hard rap type knocking... just extra shuddering from the engine.
I did the vehicle alignment procedure, as well as the front mount shim, and that got rid of a bunch of the vibration the bike had.
cuffnup
Wheels/Tires
Aug 1, 2011 12:53 PM
Moose67
Oct 13, 2010 08:34 AM
Navy Mustang
Aug 20, 2010 06:17 AM
samt
Aug 22, 2008 09:42 PM
crushem77
Jun 26, 2007 06:13 PM
