Started painting spoiler
Old Jul 11, 2009 | 12:36 PM
YellowHawk's Avatar
YellowHawk
Default Started painting spoiler
This afternoon I prepped the spoiler for paint and shot it with one light coat of gloss black. Question is, how long do I wait between coats? And, should I sand it lightly again before applying the next coat? What grit? Then, what grit should I sand with prior to clear coat?
Old Jul 11, 2009 | 01:44 PM
Two Feathers's Avatar
Two Feathers
Not really an ad, but I use this other forum alot for pinstriping and air brushing questions and technique. ( Kustom Kulture Lounge .com ).
It is run by Craig Frasier, an awesome custom painter..
I hope this helps you as much as it does me..
Old Jul 11, 2009 | 03:50 PM
YellowHawk's Avatar
YellowHawk
Thanks. I'll check it out.
Old Jul 11, 2009 | 03:55 PM
JRK5892's Avatar
JRK5892
lay light coats i assume you are using rattle can... light coat 5 - 10 min in between... then when you are done wiht the dark... go right to the clear... add a few light coats of clear... give it about 72 hrs to dry... 2000 grit wet sand wiht 1 drop of dish soap in the water (helps it to glide) knock out any peel with that... then either you can buff it out after that or you can lay another few coats of clear... wait a week, sand again and buff out... all done put on bike smile and drink beer
Old Jul 12, 2009 | 12:16 AM
MidnitEvil's Avatar
MidnitEvil
The info on the time between coats and how to apply it would be in the Product Data Sheet, if you got one.
Using Sherwin-Williams Ultra 7000 or Planet Color, I apply a medium wet coat, let it flash to hand slick (about 5 minutes), then apply my second coat. I give it about 20-30 minutes, then apply two medium wet coats of clear, back to back, no flash time.
No sanding the basecoat.
Old Jul 12, 2009 | 06:58 AM
YellowHawk's Avatar
YellowHawk
Thanks for the help. Yesterday I put on several coats of base color waiting a few minutes between coats. I didn't put on any clear because I had not read this yet and I didn't know if I needed to sand the base color. I guess I'll put on a few coats of clear today.
Old Jul 12, 2009 | 12:30 PM
MidnitEvil's Avatar
MidnitEvil
Put on some nice medium wet coats of clear - don't be skimpy. Some people try to do light coats of clear to avoid runs. That will give you a lot of texture in your clear, and possibly, poor adhesion. A couple of nice medium wet coats allow the clear to flow out, giving you a much smoother look without the need to sand & buff.
Old Jul 12, 2009 | 02:22 PM
JRK5892's Avatar
JRK5892
man i am glad you live by me
Old Jul 13, 2009 | 09:08 PM
emwolb's Avatar
emwolb
be sure to color sand it prior to clear. otherwise orange peel and overspray will be underneath your clear. 400 wet paper should be fine for color sanding. if you get the paint too heavy it'll take forever to dry. and will remain gummy down near where it is touching the primer. did you use a two part paint, with a hardener? if so, then you'll need no clear, it'll polish just like you polish lacquer.
Old Jul 13, 2009 | 09:16 PM
moosh's Avatar
moosh
mom was right..learn something new every day
