Stupid Wheel Chock Question
Old Jul 15, 2009 | 06:00 PM
mcdaniel52761's Avatar
mcdaniel52761
Default Stupid Wheel Chock Question
On the Harbor Freight wheel chock below where the black circles are......how tight or loose are those suppose to be?
Old Jul 15, 2009 | 06:27 PM
RollaMo's Avatar
RollaMo
They should be lose enough, so that section swivels as you roll your front tire into the chock.
It might even be a pin going through the holes, with a cotter pin holding it in place. Hard to tell
Old Jul 15, 2009 | 07:23 PM
Toypuller's Avatar
Toypuller
No pin in those, there is 3 holes for adjustment for different sized tires.
I just snugged them up, never had any issues.
The Dyna front tire isn't wide enough to stand up safely so be careful. My wife's Heritage will free stand all day long, but my Superglide tire will allow the bike to tip partially in the chock.
Old Sep 27, 2009 | 06:25 PM
Marty1215's Avatar
Marty1215
2nd Gear
I have a Heritage and just picked up this chock from Harbor Freight. The directions aren't very specific when it comes to adjustments for tire sizes. What hole of the 3 on the pivot would you use? Does it hit the bottom of the fender on the way up? Or am I just being to cautious?
Old Sep 28, 2009 | 08:01 AM
Toypuller's Avatar
Toypuller
Heritage will use the bottom hole.
Clearance in not an issue.
Once you slap it in a few times, you'll get used to it.
Old Sep 28, 2009 | 05:12 PM
Marty1215's Avatar
Marty1215
2nd Gear
Thanks Toypuller, I appreciate hearing it from someone that has experienced it.
Old Oct 16, 2009 | 07:14 PM
Marty1215's Avatar
Marty1215
2nd Gear
Finally put the Heritage in the HF Chock. Used the lowest hole and no issues with fender clearance. It does take a little getting used to getting it in there. A little awkward getting out, but it comes out just fine. Thanks again Toypuller.
theojkett
General Topics/Tech Tips
Mar 20, 2021 06:34 AM
GPLHeritage
May 22, 2017 11:27 PM
TheShrink
Feb 7, 2010 11:03 AM
roscoe46
Dec 23, 2007 05:56 PM
JerrySC
Jul 11, 2006 12:02 AM
