Iniminators
It's all good dude...you'll just be a fu**in pro at it! I started a thread a while back when I installed mine stating that I tried valves & springs separate times also tried levels of sag & different spring configuration with the works set (5-6 times apart in a day), best final result for me was both works springs & ricor valves, don't remember the spring configuration I went with, but I did write it down somewhere! Anyhow, ya just gotta play with it & figure out what type of ride ya like best for you! For me the valves were a good improovement, but I felt there was more on the table as far as the springs went & sure as sh** the works with the right set up was another great improvement!
That's moreorless what I told Brian @ Ricor. Told him I appreciated that level of customer service.
I just don't know if the oversized insert gave me a hard ride or what. I'd almost rather just put in some aftermarket springs and go from there. I don't know.
Pull the front end apart to swap Intiminators. Test. Possible front end disassembly again to remove / install aftermarket springs (Progressive / Works). That would make like 8 times I've had that front end apart since April/May.
CB
Ricor sent me a replacement set of intiminators but I have not been able to install them. If I have the time, it's bad weather...when it's nice I don't have the time. Remember, no garage so Im at the mercy of mother nature.
I have installed Ricor Intiminators on my SG Custom '08 and replaced stock fork oil with the one supplied with it. The feeling is that the fork is too hard and does not go well with my rear Ohlins shocks.
Newellhole
Jan 25, 2016 02:35 PM
