Changed Fork Oil Now What
Old Apr 27, 2012 | 03:13 PM
dwatkins's Avatar
dwatkins
Default Changed Fork Oil Now What
Well, The front of my bike a 94' Heritage is very soft and seems to dive to much when braking. I can set on the bike hold the front brake and pretty much bottom the front forks out. I changed the fork oil in it today and that did nothing. Whats the next thing to check? The damper tubes is my guess but not sure how hard they are to get to and how far the front end has to come apart? I'm not afraid to work on it just wanting to get an idea of what I'm getting into. And I do have a HD service manual. Any ideas?
Old Apr 27, 2012 | 03:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Do you know if anyone changed the springs in your forks?
I think you will have to rebuild the forks.
Old Apr 27, 2012 | 03:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your fork springs are shot...
They are not expensive. An easy do it yourself project.
Old Apr 27, 2012 | 04:55 PM
dwatkins's Avatar
dwatkins
Springs are factory but the front end was rebuilt two years ago when the chrome front end was put on. Springs should be an easy fix then.
Old Apr 27, 2012 | 05:14 PM
JohnFlorida's Avatar
JohnFlorida
You can try putting in an extra once of oil in each tube
Old Apr 27, 2012 | 05:34 PM
schwangster's Avatar
schwangster
I'll recommend what I've done-
Racetech (or other) straight rate springs for YOUR weight
+ Ricor Intimidators with Fabrik8r mods and Amsoil 5W.
The springs alone, with some heavier oil, will improve the ride.
But the Ricors really control the wheel travel, brake dive and change the ride.
I had mine modified by Fab to work way better than stock Ricors.
There are other more expensive options, but I'm liking my front end now.
Old Apr 27, 2012 | 07:26 PM
Dally-44's Avatar
Dally-44
Is it just the fl's that have the air valve on the handlebar?
Old Apr 27, 2012 | 09:39 PM
SportsterBob's Avatar
SportsterBob
A new pair of fork springs will make a big difference if the forks bottom out easily.
Old Apr 27, 2012 | 09:57 PM
Jethro's Avatar
Jethro
Do be aware that this is not difficult to do, but you need a manual, and you should replace the seals and bushing if they were not done before. Also, you really should have access to a pneumatic impact wrench.
Old Apr 28, 2012 | 05:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The front end will still bottom out easily, the springs are shot.
