rubber mounted bars
Old May 29, 2006 | 12:17 PM
dog06bob's Avatar
dog06bob
Default rubber mounted bars
Just an FYI for anybody with apes of any kind. I replaced the the rubber riser bushing on my streetbob with the Harley polyurethane bushings part #56165-03, about 35 dollars. What a difference. No more mushy feel. Perfect control. Probably the best thing I've done for the bike yet.
Old May 29, 2006 | 12:21 PM
theyogawarrior's Avatar
theyogawarrior
Default RE: rubber mounted bars
I'm also thinking about doing this. What do you feel makes such a big difference? Thanks.
Old May 29, 2006 | 10:55 PM
dog06bob's Avatar
dog06bob
It's almost like a solid mount. With any type of ape bar you have too much leverage therefore creating a greater flex at the mounting point. With the mushy rubber mounts it kind of gave the front end a mind of it's own, which I certainly don't want.
Old May 30, 2006 | 06:54 AM
SDMF's Avatar
SDMF
ORIGINAL: dog06bob
Was this an easy change-out??? I'm replacing my bars very soon and never thought about that.
Old May 30, 2006 | 09:20 AM
dog06bob's Avatar
dog06bob
it was real easy. Don't follow the directions though. I know you said you were changing your bars, but for anybody else. They tell you to remove your bars. not necessary. Remove one riser bolt and you can twist the riser out of the way to change the bushing, install bolt and repeat for the other side. This avoids having to diconnect your cables or have the bars laying on your tank like the directions say. I do suggest having another set of hands to keep the loose riser from hitting anything.
Old May 30, 2006 | 09:47 AM
SDMF's Avatar
SDMF
Thanks dog!!! I can't wait to get the bars on. After that, it's Bassani Pro Streets with black heat wrap and my own custom tooled leather on a custom seat pan.
Old May 31, 2006 | 05:00 AM
veniculum's Avatar
veniculum
did it a couple months ago. Definitely worth the 35 bucks. I hated the mushy feeling
Todd
Old May 31, 2006 | 06:01 AM
SDMF's Avatar
SDMF
Got all my cables and lines ordered yesterday and I made sure there's enough length OS to move up to a set of 16" bars if I chose. Also, I'm heading to my stealership today to pick up a set of new riser bushings. If all goes well, I should have some new pics to post by next week. Thanks to all for your input. [sm=happy046.gif]
3itodd
Sep 21, 2025 07:43 PM
acd118
Aug 27, 2014 11:36 AM
blackeg84
Jun 13, 2014 12:53 PM
skidonkey
Feb 20, 2010 10:06 AM
ghostrider69
Oct 20, 2009 12:38 AM
