Riding 2 up
Old Aug 7, 2007 | 05:45 PM
jaxdwg's Avatar
jaxdwg
Default RE: Riding 2 up
I have an 02 wideglide and have 75k on it. About 85% of my riding is 2-up. I put on the 1/2 in. longer progressives on the rear and did nothing to the front except the next heavier oil and we are quite comfy and it handles good too. With your bike it should be a piece of cake. Take mama with and she'll be nicer to you when you get home . I was taught that if you tell yourpassenger to look in the direction of the turn she will naturally lean the proper amount, it works good for me------jack
Old Aug 7, 2007 | 06:06 PM
falsealarm's Avatar
falsealarm
Ride alone most of the time. I am only 127lbs, wife around 150. Just went with the stock press. Think I should add air everytime we go 2 up? thanks guys
Old Aug 7, 2007 | 06:19 PM
hedgehogch53's Avatar
hedgehogch53
just took the wife for a ride two up on a street bob. i'm 208 she is 130. adjusted the peload up two clicks and tire press to manual specs....no prob. when i was 260 and she 130 with factory adjustment we scraped bad on righthand turns.
Old Aug 7, 2007 | 06:56 PM
seaox's Avatar
seaox
88- check your manual.. unfortunately you are way, way,way over the GVW ( gross vehicle weight). Not wise to ride with your passenger. check it out!
Old Aug 7, 2007 | 08:12 PM
Cloud09King's Avatar
Cloud09King
I weigh about 220 & my wife about 160. My advice...don't even go into the whole "leaning with me" lecture. I just told my wife to sit back & relax & let me worry about the driving. Although you should add a little bit more air to the back tire, I never have & I've only botomed out the shocks once going over a decent size pot hole. Only difference with riding a passenger...a little more throttle at take-off, can't curve into corners like you'd normally do & preparing to stop a little bit sooner than normal with a bit more brake applied...that's really it. At the request of my wife, I m putting on a low size sissy bar as she said she'd feel a bit more comfortable & secure. Riding with a passenger is fun...enjoy!
Old Aug 8, 2007 | 06:25 AM
Sargent1's Avatar
Sargent1
6th Gear
Neither of us lean. I countersteer.
Nickd2689
Feb 1, 2017 06:30 AM
Harley Cycle
Mar 13, 2013 03:15 PM
LOWRY
Exhaust System Topics
Apr 5, 2006 12:48 AM
greenbayhog
Mar 16, 2005 04:56 PM
