tires
Old Jun 2, 2006 | 03:45 PM
jbrewer's Avatar
jbrewer
Default tires
anyone running low profile tires? metzler doesn't reccomend them. any comments.
Old Jun 2, 2006 | 04:20 PM
ReeseSS's Avatar
ReeseSS
Default RE: tires
Did they say why they don't? When I added the wide tire kit and used a 240 metzler it really dropped the back end down too much, had to go to longer shock to put road clearence back to about stock, so wondering if that is why. If so can be corrected and should not be a reason not to use them as long as someone is aware it will change the ride height.
Old Jun 2, 2006 | 04:45 PM
jbrewer's Avatar
jbrewer
Default RE: tires
The faq on the metzler site only said it could cause handling problems. I thought I could get my bike a little lower with the low profile tires. HD always tell you everything you change will cause problems, but all the changes so far have only helped.
Old Jun 2, 2006 | 04:53 PM
ReeseSS's Avatar
ReeseSS
Default RE: tires
Probably just a typical disclaimer, if getting lower is what you are looking for, they will do that for you. Bet they handle just fine!
Old Jun 2, 2006 | 05:01 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Default RE: tires
I am going to add the 11" Progressive 412's soon. This will put the fender further down on the tire and probably lower the frame close to 1 inch. I like the idea of a lower profile tire and figure it would only help handling.
Let's see some photos of some low bikes.
Old Jun 2, 2006 | 05:03 PM
jbrewer's Avatar
jbrewer
Default RE: tires
thanks for the input. the sport sets real high i have already changed the seat and shocks, but i am still not where i want to be. I think the tires will do it, can't afford to trade.
Old Jun 2, 2006 | 06:44 PM
ROADTRAIN's Avatar
ROADTRAIN
Default RE: tires
ORIGINAL: jbrewer
This is a Michelin low profile fitted on a Streetbob, the bike handles and rides OK. This is the same tyre fitted to the Buels. Tire manufactures and dealers will only recommend original tire sizes. If the speed rating is right then you won't have a problem.
Old Jun 2, 2006 | 08:01 PM
jbrewer's Avatar
jbrewer
Default RE: tires
Do you have low profile on front and rear?
Old Jun 2, 2006 | 08:16 PM
jmbear328's Avatar
jmbear328
Default RE: tires
ReeseSS,
Thats a great looking bike. What wide tire kit are you using, and how much $$$ did it set ya back?
John
Old Jun 3, 2006 | 12:19 AM
ROADTRAIN's Avatar
ROADTRAIN
Default RE: tires
ORIGINAL: jbrewer
The front I lowered by sliding the the tubes up through the tripple tree. The tire is standard size, you can get a low 19" but you require a wider rim.
fhartell14
Apr 21, 2018 07:03 AM
BuzzCap7
Wheels/Tires
Mar 3, 2015 08:10 PM
DILLIGAF-MIKE
Wheels/Tires
Apr 26, 2010 04:07 PM
1bagman
Jul 28, 2008 11:47 AM
Jonpaul
Apr 24, 2007 04:52 PM
