Side mount plate, wiring question
Old Aug 18, 2009 | 10:04 PM
Vinsil's Avatar
Vinsil
Default Side mount plate, wiring question
Can't remember the guys screen name that did this, but I was wondering how and where the wires were ran.
I have an 09 SB, plan to cut off the factory mount. I have a vertical plate holder with LED's in it, and need to wire them up. It is going on the upper belt guard and I don't see a clean way to run the wiring without it either going along the swing arm, the belt guard (which I was going to remove but might have to leave on for the wiring) or having them run up to the fender. Also, where did you tie into to use the plate lights? I have a white/black (power-ground).
I searched and didn't find much help. Thanks, I plan to post pictures after I figure a good way to run the wires.
Old Aug 18, 2009 | 10:16 PM
bberck's Avatar
bberck
I ran mine on the inside of the swingarm, using a few zipties in places you cant see and some thick 3m tape over the top of it all. Cant see any of it and has held great so far.
As far as power I tapped into the rear brake light harness under the seat. I believe it was the blue wire that was the power but I would double check the service manual.
Old Aug 18, 2009 | 10:46 PM
Vinsil's Avatar
Vinsil
Thanks for the reply. That is most likely the best way.
Old Aug 19, 2009 | 12:29 AM
NoLongerAmember's Avatar
NoLongerAmember
This looks like a clean way to do it.
Old Aug 19, 2009 | 12:46 AM
OhioSkully's Avatar
OhioSkully
as bbreck said when i mounted mine i got some of the 3m sticky brackets that have the metal tab put on the inside of the swing arm and layed wire in them and pushed over the tab. Then up the frame under the seat. I pulled the connector for the rear light and found the wires for the license plate running light and just pulled those wires out and soldered my two wires on to them and shoved them back into the connector and hooked it back up no problems yet knock on wood. don't have my book or i would tell you which two wires it is. I believe it is the blue but cant say for sure.
digitalhippie
Apr 24, 2012 09:14 AM
zonutt
Mar 15, 2010 05:38 PM
EricInNCa
Feb 10, 2010 11:48 PM
OhioSkully
Feb 7, 2009 11:14 PM
drkenigma1
Nov 6, 2008 02:12 PM
