Putting on pipes, any issues?
Old Aug 20, 2009 | 11:39 AM
logdon17's Avatar
logdon17
Default Putting on pipes, any issues?
So I am finally getting around to putting a new set of pipes on my bike. They are samson big guns and I am wondering if it really is as easy as unbolting the stock ones and bolting on the new. Can anyone who has put pipes on their bike (from the header) give me any tips? Thanks!
Old Aug 20, 2009 | 11:44 AM
RCB's Avatar
RCB
Be sure to replace the exhaust gaskets.
Old Aug 20, 2009 | 12:20 PM
thedonthere's Avatar
thedonthere
Tighten the flange nuts, ride it and check the flange nuts again. Don't over tighten them and squeeze the gasket out into the exhaust port.
Old Aug 20, 2009 | 02:16 PM
Ratbob's Avatar
Ratbob
All good tips above! It took me about 4 rides followed by torquing to get mine seated. For the initial tightening, torque all four to about half the specified torque requirement, then torque all four to spec. Use a stick of incense to check for leaks.
Old Aug 20, 2009 | 02:28 PM
bberck's Avatar
bberck
Keep lots of towels around to keep from putting marks on them. Nothing worse than getting them installed but putting a big scratch down them.
Old Aug 20, 2009 | 02:31 PM
BiggDogg's Avatar
BiggDogg
Great tip with the incense,
I was smoking a cigar so i tried using that. Come to think about it, it's been a month with my exhause. I should check the bolts again
Old Aug 20, 2009 | 10:58 PM
ackman1968's Avatar
ackman1968
It really is that easy. Get after it and enjoy the fruits of your labor.
Old Aug 20, 2009 | 11:03 PM
joe.1955's Avatar
joe.1955
Use stock replacement gaskets - not the SE ones.
Old Aug 21, 2009 | 12:20 AM
Ground Control's Avatar
Ground Control
Sorry for the hijack, but does anyone know the torque specs of the head bolts for the '09 Super Glide? (I'm saving up for a service manual, but would sure like these specs at the moment). Thanks.
Old Aug 21, 2009 | 04:06 AM
Airborne350G's Avatar
Airborne350G
Here are the torque and sequence for an '07. Should be the same for the '09:
1. Install lower nut and tighten finger tight
2. Install upper nut and tighten to 9-18 in-lbs(1-2 Nm)
3. Tighten lower nut to 60-80 in-lbs (6.8-9.0 Nm)
4. Tighten upper nut to 60-80 in-lbs (6.8-9.0 Nm)
Then after riding a few miles I would double check them again.
