Quick Riser Question
Old Aug 21, 2009 | 03:23 PM
Quickie's Avatar
Quickie
Default Quick Riser Question
Can anyone tell me how long of a riser I can use on my stock St Bob handle bar before I have to change cables? I installed my new solo Mustang seat and I need to bring the bar back and up a little. Maybe a couple of inches each way. Just wondering how anyone else solved this reach problem without having to change everything.
Old Aug 21, 2009 | 04:29 PM
JRK5892's Avatar
JRK5892
what year? i went up 3 in on my 06 with stock cables and stock bars before i got my new bars and risers... was super easy i made my own spacers to make it work... the 07+ models have dif cables
Old Aug 22, 2009 | 06:28 AM
Quickie's Avatar
Quickie
Sorry the bike is an 06. There apears to be 2in straight risers stock,and i was wondering if i could go to a 4in with a pull back design.
Old Aug 22, 2009 | 08:27 AM
boutellepc's Avatar
boutellepc
I have an 07' and used 4" pullback risers and they just made it.
Old Aug 22, 2009 | 05:02 PM
Skyking75's Avatar
Skyking75
Default Stock Size
I am confused. I was thinking about installing some risers myself. Am I correct in assuming that stock is 2". So if I want to raise 1", I should buy a 3" riser? The 4" riser is 2" above stock and is close to the limit without changing anything
Old Aug 22, 2009 | 05:15 PM
Gary7's Avatar
Gary7
I thought the Street Bobs had built-in risers that could not be replaced.
Old Aug 22, 2009 | 11:02 PM
redlohsom's Avatar
redlohsom
You are correct sir....However, look around on here for another tread about a guy who makes risers for the Street Bob. They look pretty good. I was going to get a pair of 4 inch but the price is about the same just to buy new bars so I think I'm going to just do that since I'll have to change out the throttle and clutch cable to get 4+ more inches on an 08" FXDB
Old Aug 23, 2009 | 01:11 AM
Wonkaboy's Avatar
Wonkaboy
Post
Definally straight 6" risers will fit because i just installed them on my 2006 Street Bob Tuesday nite , no problems with any cables etc. but it also depends on your bars design too, with my "Frisco's" everything reached perfectly , Cables , controls , etc. , 6 inches is the tallest you can go without having to change anything else , i will post photo's Sunday nite ( Hopefully )
Old Aug 23, 2009 | 09:00 AM
Chipstah's Avatar
Chipstah
Default Similar issue
I had the same issue as the OP due to my Mustang solo on my '07 St Bob (non-integrated risers) -- went with 3" risers (ie +1" over stock) with separate clamps so I could also install a Baron tach that I got cheap from a forum member between the risers while I was at it -- had no problem with cable lengths but did rotate one right side lower handle bar cable clamp 180 degrees to reduce some tension on brake cable. Doubt you could go much higher with the stock mini-apes. Solved the problem for me and retained original riding position (seat/handlebar relationship) -- and not a very expensive way to go without needing new cables and their installation.
Old Aug 23, 2009 | 09:14 AM
ghostrider69's Avatar
ghostrider69
They started integrating them into the triple tree on 08'.
