I have a new set of Thunderheader pipe in hand, but don't know how to start?
read some post said that need new gasket, which doesn't come with the kit!!
the manual claimed that need to remove clutch release cover and 4 lower bearing housing bolts, what is that?????
what else does it need to complete this installation?
What tool do I need to put them on?
Go buy some new exhaust gaskets at your local hd dealer... ask them about the clutch release cover and housing bolts.
I didn't take off the clutch release cover... just loosened it a bit to get to the last of the four bolts on the housing unit(it hides behind where the clutch cable goes into the unit)... got mine on in about 30-45 min. It's not that hard... just have to jiggle and fiddle a bit to get it to fit.
Where exactly is the clutch release and that 4 bolts?
sorry I'm such an idiot! any photos?
BTW...what it has to do with those part? as I know the clutch is on the left side? and wonder what bearing it can be involve?
The clutch lever is on the left side, but the cable goes into the right side where the mechanism is.
Look towards the rear of the throttle side of your bike for the cover that says 6-speed...it might be a clue!
WTF? Clutch release cover? The THeader is a straight installation. You just unbolt the last pipe, and bolt this one on. Fairly straight forward. It may use different bolts on the tranny cover, but its straight forward and everything lines up.
Do some searching man, there are several threads besides the one posted above that will answer all your questions with pics and instructions. Take a deep breath, you sound a bit overwhelmed in you original post. Just take it step b step and it will be alright.
My 2-1 has a different bracket than the one that comes with the stock pipes...would imagine the same for these.
Do yourself a HUGE favor and buy a service manual. Read the TH install sheet and then refer to the service manual and look up what you do not understand or are not familiar with. This is the method I used. I also searched the dyna forum for anything related to Thunderheader. There are alot of helpful posts out there.
Good Luck!
