06 Bob...problems or normal?
Old Jun 7, 2006 | 06:58 PM
Cory's Avatar
Cory
Default 06 Bob...problems or normal?
Now that I've had my 06 Bob for a while, I've compiled a few things that I'm not sure are normal or maybe could be problems....
1. When front brake is applied it sounds like a cricket chirping really fast.
2. When at parking lot speed I can hear a sshhhh noise that sounds like the front brake is dragging.
3. When coming to a stop, the front end shudders/vibrates slightly at certain points of speed and rpm (when the front brake is applied and clutch is in it's most noticeable)
4. Front end clunks when hitting bumps or sometimes when applying the front brake.
5. Tranny clunks loudly when putting into 1st gear after startup.
problems or normal?
Thanks
Old Jun 7, 2006 | 07:07 PM
Whiffleboy's Avatar
Whiffleboy
Default RE: 06 Bob...problems or normal?
I've got numbers 3, 4, and 5. I heard #3 is the floating rotor and #5 is normal. #4 sounds like all kinds of things are loose on my front end, yet, I can't find anything. [8D]
Whiff
Old Jun 7, 2006 | 07:50 PM
dubblist's Avatar
dubblist
Sound like most of these issues are from the older Bob's that first came out? I havent heard of many issues with the current ones coming of the line. God I hope..lol. I'm picking mine up this week and I'm nervous as hell reading things like this all the time
Old Jun 7, 2006 | 07:54 PM
CoolChrome's Avatar
CoolChrome
So number 3 is normal ? cuz i have it too..
Old Jun 7, 2006 | 07:57 PM
Whiffleboy's Avatar
Whiffleboy
#5 is common. #3 is only what I've heard.
Whiff
Old Jun 7, 2006 | 08:03 PM
06streetbob's Avatar
06streetbob
1 mine does the same thing.
Old Jun 7, 2006 | 08:05 PM
Cory's Avatar
Cory
ORIGINAL: dubblist
mine is only 1 month old.
I'm sure most of it is just "the sounds a Harley makes"....none of it is really terrible sounding, I'm just over-sensitive since it's new.
Old Jun 7, 2006 | 08:29 PM
Cory's Avatar
Cory
Whif, since you mentioned floating rotor, I decided to do some research on that....
It appears that 1-4 can all be attributed to the floating rotor. I found several other people that have narrowed down at least one of those noises each to the floating rotor.
Old Jun 7, 2006 | 08:36 PM
JamieWG's Avatar
JamieWG
You guys just need louder pipes.
Old Jun 7, 2006 | 08:46 PM
Cory's Avatar
Cory
ORIGINAL: JamieWG
True!
