front wheel removal
Old Sep 1, 2009 | 07:31 PM
QuickSilver74's Avatar
QuickSilver74
Default front wheel removal
is there any way i can remove the front wheel from my bike with a floor jack?
i dont have a motorcycle jack but if i can find one for a good price i'd buy one.
i need to take the front wheel off so i can polish the spokes that i sprayed some cleaner that was too stong on.
Old Sep 1, 2009 | 07:33 PM
Bobbed Out's Avatar
Bobbed Out
rig something up .. i'm sure if you can figure a way to lift it onto a block it would be fine
Old Sep 1, 2009 | 07:47 PM
QuickSilver74
how would i keep the bike stable as i lift it?
Old Sep 1, 2009 | 07:50 PM
Bobbed Out's Avatar
Bobbed Out
i would definitely suggest having someone else handy when you do it .. not a woman .. someone that can do something
then have them stabilize it as you lift it and try to slide something underneath the middle of it?
just and idea i've never done it but that's how i guess i'd do it
Old Sep 1, 2009 | 08:21 PM
Desertdog7's Avatar
Desertdog7
Default Lift
Get a floor jack... a nice flat piece of wood... 2x6. check under your bike to make sure your not squashing anything important.... i.e cluth cable, oil pan, or anything else lower than your frame. Need two people for this btw... place the jack and wood under your bike frame(somewhat center as as you can) One person stradle the bike other person lift the bike. Lift it just enough to place two jack stands under your forward foot peg mounts(where they mount to your frame). If you got them? Thats how i Did it on mine. Worked Great!!!
Old Sep 2, 2009 | 08:06 AM
seaox's Avatar
seaox
This is a good help .
www.nightrider.com/biketech/bikelift.htm
Old Sep 2, 2009 | 08:28 AM
damfino's Avatar
damfino
Did the same when i removed my front end. Used a tie down strap attached to each jack stand to keep the bike secured. Worked great. You will need help during the jacking operation to steady things before the jack stands are in place.
Malazan
May 15, 2019 02:31 PM
notrailers
Aug 7, 2012 08:23 PM
inswva
May 9, 2011 08:54 PM
pretz
Oct 3, 2010 06:03 PM
HogHal
Nov 8, 2006 11:56 AM
